Alberto Rico Posted January 10, 2023 Author Share Posted January 10, 2023 Hi I put CCleaner Fix.app in the Applications Directory. I ran and in the system.log I got this message: Jan 10 12:03:41 iMac-de-Imac com.apple.xpc.launchd[1] (com.piriform.ccleaner.1944[578]): Service exited with abnormal code: 1 I restarted the computer as well, ran the sent program and CCleaner.app and nothing happened. The error message is the same for both cases. The strange thing is that CCleaner works fine for the other users of my computer. Alberto Rico Link to comment Share on other sites More sharing options...
Alberto Rico Posted January 10, 2023 Author Share Posted January 10, 2023 HELLO Megan, finally CCleaner worked. I executed in Terminal the command: /bin/launchctl load -w /LibraryAgents/com.piriform.ccleaner.plist and the program started. Thank you very much for your help Megan Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 10, 2023 Moderators Share Posted January 10, 2023 8 minutes ago, Alberto Rico said: HELLO Megan, finally CCleaner worked. I executed in Terminal the command: /bin/launchctl load -w /LibraryAgents/com.piriform.ccleaner.plist and the program started. Thank you very much for your help Megan Do you have to do that every launch or did it fix it completely? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Alberto Rico Posted January 10, 2023 Author Share Posted January 10, 2023 Megan, fix it completely. I have only a message when I open CCleaner after restart or start the computer I got a message like this: The CCleaner application is no longer open. I close the message and try again and it opens without problem. Link to comment Share on other sites More sharing options...
