Bigyun2000UK Posted March 18, 2021 Share Posted March 18, 2021 Hi all. I just purchased CCleaner Professional PLUS. How do I access the Disc Defragmentation, File Recovery and Hardware Inventory? Many thanks Bigyun2000UK Link to comment Share on other sites More sharing options...
Moderators nukecad Posted March 19, 2021 Moderators Share Posted March 19, 2021 You need to download/install each one seperately and enter you registered name and key into each. It's done that way so that you can pick and choose which you want to download/install and which you don't need. To avoid all the marketing information you can download the installers for each from these simple pages: CCleaner: https://www.ccleaner.com/ccleaner/builds Defraggler: https://www.ccleaner.com/defraggler/builds Recuva: https://www.ccleaner.com/Recuva/builds Speccy: https://www.ccleaner.com/Speccy/builds Once downloaded and installed you go to 'Options>About' or 'Help>About' and click on 'Upgrade to Pro', enter your registered name/key, and then click 'Register'. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
trium Posted March 24, 2021 Share Posted March 24, 2021 On 18/03/2021 at 22:04, Bigyun2000UK said: Hi all. I just purchased CCleaner Professional PLUS. How do I access the Disc Defragmentation, File Recovery and Hardware Inventory? i have this question for some time ago...there should be a one file installer to download... Quote If you download the Professional Plus installer (link in your confirmation email after purchase) then you should be greeted with this on the second screen after you select your language: Versions of CCleaner Cloud; Introduction Ccleaner Cloud; Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to comment Share on other sites More sharing options...
