Rich1234789 Posted May 7, 2020 Share Posted May 7, 2020 I have a ryzen threadripper 1920x machine with an aorus motherboard. -CPUID HWMonitor is reporting between 29 deg and 38 deg c -Core Temp reports about 28 - 38 deg c Speccy reports 58-70+ deg c. Is there a problem with my machine, or is speccy right and the other things wrong? Link to comment Share on other sites More sharing options...
homer525cz Posted May 8, 2020 Share Posted May 8, 2020 Hello, today i updated my bios and now speccy shows wrong temperature of MB. asus B150M PRO gaming PIC OF PROBLEM Link to comment Share on other sites More sharing options...
xorkatoss Posted May 30, 2020 Share Posted May 30, 2020 (edited) so I guess this is a common problem with Speccy eh? Ryzen 5 1600 AF! Speccy has wrong temperatures and actually detects it as 14nm instead of 12nm as it should be. Edited May 30, 2020 by xorkatoss Link to comment Share on other sites More sharing options...
Hiddengerbil Posted May 30, 2020 Share Posted May 30, 2020 At this point, this issue has gone on for so long, that I suspect they are never going to fix this in the free version... Link to comment Share on other sites More sharing options...
Jim B Posted November 1, 2020 Share Posted November 1, 2020 Speccy Is reporting CPU temperatures as high as 90°C. I don't think that can be accurate because, if it was, the air that is the fan is blowing out of the heatsink would very hot and you would not be able to touch the heatsink. Both feel only slightly above ambient temperature, 69°F Operating system: Windows 10 home 64-bit Computer manufacturer: ZT systems Model number: 7645 Mi CPU: Intel core i5 2320 Motherboard: MSI H 67 MA – E 45 (MS – 7678 Chipset vendor: Intel Chipset model: Sandy Bridge Chipset revision: 09 Jim Birke Link to comment Share on other sites More sharing options...
Adam03 Posted December 21, 2020 Share Posted December 21, 2020 So this thread was started in 2015. Here we are in December 2020 and I have just checked three different drives all currently attached to the PC with one internal (SSD) to the PC and two external drives in a dock. All are reported by Speccy as 31degrees. I have been doing intensive repetitve work with the two external drives in a dock and they are almost red hot (slight exaggeration but certainly only a degree or two off being uncomfortable to touch). How on earth can they all be reporting at 31 degrees ? Seriously I wonder about any of the software this Company produces as I have also had issues with CCleaner and Defraggler - and they seem to take years to be fixed if at all. I am only glad the price is right because there is no way I'd pay for any of it. Link to comment Share on other sites More sharing options...
Pete Zuroff Posted July 8, 2021 Share Posted July 8, 2021 ASUS B450M-PLUS GAMING (AM4) motherboard, Ryzen 2700X cpu , speccy shows incorrect temperatures of cpu and its cores. Link to comment Share on other sites More sharing options...
JoesCat Posted October 27, 2021 Share Posted October 27, 2021 A search yielded this thread so might as well add my observation here. The one issue I'm having with the now current version 1.32.774, registered: I have it set to run on startup to display the CPU temp in the system tray (Windows 10 20H2). The displayed temperature shows a particular number (usually higher than actual) and never updates. I have to open the GUI then minimize to enable the temperature to update. On my system (MSI Creator 17 A10SFS) Speccy is close to the reported CPU temp in the MSI utility Creator Center. Link to comment Share on other sites More sharing options...
