Septuaginta Posted September 27, 2016 Share Posted September 27, 2016 I have Speccy Pro on a two month old Acer Desktop computer with an Asus motherboard: Manufacturer ASUSTeK COMPUTER INC. Model M32CD_A_F_K20CD_K31CD (LGA1151) Version Rev 1.xx Chipset Vendor Intel Chipset Model Skylake Chipset Revision 07 Southbridge Vendor Intel Southbridge Model Skylake PCH Southbridge Revision 31 System Temperature 120 °C Speccy show an abnormal temperature in the motherboard. None of the other components are this high, they are running to spec! Because the computer is still under guarantee, it has been back to the supplier (John Lewis UK) twice. On the last occasion they sent it to be tested by an Asus agent in East Kilbride Scotland. The board functions correctly according to both sets of technical support and they did not find the temperature of the motherboard to be at 120C as reported by Speccy. What gives? and if this is wrong how much confidence can we give to the other data produced by Speccy. Link to comment Share on other sites More sharing options...
Saiph Posted September 30, 2016 Share Posted September 30, 2016 Last night Microsoft forced me (with only 10 mins notice!) to update my Windows 10 Home 64-bit to version 1607, build 14393.187. I believe this is also called the "anniversary update"? A number of friends have posted that this update has caused them severe problems, so after it completed I have been checking my PC quite thoroughly. The only unusual thing I have noticed is that Piriform Speccy is reporting an abnormally high temperature for the motherboard system temperature. This is being shown at around 111degC. The temperature display was correct before the Win10 update. I tried reinstalling Speccy (v1.29.714) and alternating the options from 'metric C' to 'Imperial F' but this did not fix the problem. I have followed the advice in post #1 and updated my BIOS to the latest version, but again this has not helped. Manufacturer: ASUSTek COMPUTER INC.Model: H87-PLUS (SOCKET 1150)Version: Rev X.0xChipset Vendor: IntelChipset Model: HaswellChipset Revision: 06 (BIOS now updated to version 2003, release date 15/10/2014) Thanks for any help you can give. Link to comment Share on other sites More sharing options...
DJCoffee Posted October 10, 2016 Share Posted October 10, 2016 Hello Piriform, I built my wife a computer, and the motherboard is showing temps of 110C+(230F+). BIOS was updated, but the issue remained. MSI H170 Pro AC 1.0 Intel Skylake 07 Thanks for making excellent software Link to comment Share on other sites More sharing options...
Kabal52 Posted October 24, 2016 Share Posted October 24, 2016 https://forum.piriform.com/index.php?showtopic=47217Wrong Motherboard tº Link to comment Share on other sites More sharing options...
wigga whambo Posted November 15, 2016 Share Posted November 15, 2016 My problem here is the graphics card which is showing 952 degrees F https://imgur.com/WsKturT Latest BIOS has been installed Manufacturer: DellModel: 0CD3KR (U3E1)Version: A00Chipset Vendor: IntelChipset Model: ID1910Chipset Revision: 07Please fix. Thank you. Link to comment Share on other sites More sharing options...
-benediction- Posted November 18, 2016 Share Posted November 18, 2016 Wrong Temperature on ASUS H97 Plus, as seen on Screenshot Link to comment Share on other sites More sharing options...
Coreinkb Posted November 30, 2016 Share Posted November 30, 2016 I'm getting wrong temps it always stays at 28°C when it should be bouncing around from 32 - to 40 just depends how hot is the weather. Motherboard Manufacturer Gigabyte Technology Co. Ltd. Model H110M-H-CF (U3E1) Version x.x Chipset Vendor Intel Chipset Model Skylake Chipset Revision 07 Southbridge Vendor Intel Southbridge Model Skylake PCH Southbridge Revision 31 Note that this is DDR4 version because there's the same model of this motherboard that uses DDR3, Maybe that explains why my ram type shows as Unknown. Link to comment Share on other sites More sharing options...
dantasm Posted December 1, 2016 Share Posted December 1, 2016 Manufacturer ASUSTeK COMPUTER INC.Model H87M-E (SOCKET 1150)Version Rev X.0xChipset Vendor IntelChipset Model HaswellChipset Revision 06 Showing motherboard temp of 245 degrees F. Other temps are fine. "Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming, WOW! What a Ride!" Link to comment Share on other sites More sharing options...
merkxr Posted December 2, 2016 Share Posted December 2, 2016 I just updated, about 15 minutes ago, to the latest version V 1.30.730 and it is now showing incorrect motherboard temp. it's showing 118 degrees C. In the four years I've used Speccy I've never had this issue. MB temps have always remained ~20(ish) degrees C. Please fix. Manufacturer ASUSTeK COMPUTER INC.Model Z97-K (SOCKET 1150)Version Rev X.0xChipset Vendor IntelChipset Model HaswellChipset Revision 06Southbridge Vendor IntelSouthbridge Model Z97Southbridge Revision 00System Temperature 118 °C << This is way off! Link to comment Share on other sites More sharing options...
hotvirgin Posted December 3, 2016 Share Posted December 3, 2016 Small difference between CoreTemp and Speccy. But temps indicate by HWmonitor 1.30 is similar to Speccy See attached pic. Link to comment Share on other sites More sharing options...
colonelpatch Posted December 13, 2016 Share Posted December 13, 2016 Today I updated speccy and it said my MB was 114c! there's just NO way it can be that hot. If I remember correctly the older version of speccy didn't even come close to displaying it as that hot. But sure enough..https://gyazo.com/2015e2c65401f8fab8d1c61ab5d52a86So I tried another program..https://gyazo.com/f458920989b0a31c1b2d8059845c6d95Same thing! if it matters I did dust/clean out my PC a few days ago and just gave it another quick clean just to make sure. I even booted into the BIOS and my BIOS said my MB was like 26c! there's just no way it can be this hot...am I imagining things? I got this MB maybe like...in the summer? Juneish? so it can't possibly be broke can it? does anyone have any other suggestions for checking my temp?https://gyazo.com/63494b8f4788a67e03dfdf235165a45d my CPU/ram usage isn't that bad either. So what on earth could be causing such a bad temp spike?So is this just some sort of API issue? I downloaded an old version of speccy and it seems to be displaying correctly. I got a friend to try and update his speccy but his is fine..Is anyone else getting incorrect temps from temp gauges? Link to comment Share on other sites More sharing options...
colonelpatch Posted March 4, 2017 Share Posted March 4, 2017 Months later and it's still doing the same thing lol. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 4, 2017 Author Moderators Share Posted March 4, 2017 Months later and it's still doing the same thing lol. Of course you could follow the first post and instead of the long mess you presented given the data requested. The devs do read all threads and inorder to recreate a bug need information ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
jptiger Posted March 25, 2017 Share Posted March 25, 2017 Manufacturer :MSIModel: B250I GAMING PRO AC (MS-7A67) (U3E1)Version: 1.0Chipset Vendor: IntelChipset Model: Kaby LakeChipset Revision: 05 Motherboard temps generally reported as between 107-112 degrees Celcius, while MSI's own utilities report temps in the 40s.Thank you for your work and good luck squishing the bugs! Link to comment Share on other sites More sharing options...
Allsop Posted May 31, 2017 Share Posted May 31, 2017 Windows 8.1 64-bit Manufacturer: Toshiba Model: VG20SQ (Socket 0) Version: 1.40 Chipset Vendor: Intel Chipset Model: Haswell Chipset Revision: 06 AMD Radeon R9 265X: GPU temps showing 511 degrees Celcius constantly. Link to comment Share on other sites More sharing options...
GreatGeneral Posted June 3, 2017 Share Posted June 3, 2017 LoL!!! My Mobo is melting right now!!!! with 198 degrees...... lol Link to comment Share on other sites More sharing options...
xmikex Posted June 24, 2017 Share Posted June 24, 2017 temperature of xeon 775 processors is on 15 degrees higher, than in RealTemp. Link to comment Share on other sites More sharing options...
Nerf Herder Posted October 21, 2017 Share Posted October 21, 2017 Hello, I think the latest windows 10 update (windows fall update or whatever) broke something with Speccy. Motherboard temperature is showing 115 degrees. Same thing happened to me a while back, with the first Anniversary update (temp reading was fixed in a later release of speccy, thx for that)... Anyway, here goes again: Manufacturer: ASUSTeK COMPUTER INC. Model: Z97-E (SOCKET 1150) Version: Rev X.0x Chipset Vendor: Intel Chipset Model: Haswell Chipset Revision: 06 Thanks! Link to comment Share on other sites More sharing options...
Barnold48 Posted November 1, 2017 Share Posted November 1, 2017 Hersteller ASUSTeK COMPUTER INC. Modell PRIME Z270-K (LGA1151) Version Rev X.0x Chipsatz Hersteller Intel Chipsatz Modell Kaby Lake Chipsatz Revision 05 Speccy Temp 118 °C BIOS Temp 24 °C since yesterdays Windows update to Version 1709 for x64-basierte Systeme (KB4049179) Link to comment Share on other sites More sharing options...
Causticspit Posted November 23, 2017 Share Posted November 23, 2017 I have a ASUS ROG STRIX X399-E Gaming Motherboard. Speccy reports incorrect CPU Temperatures. Actual idle temp 32C, Speccy shows 62C Link to comment Share on other sites More sharing options...
Moderators mta Posted November 23, 2017 Moderators Share Posted November 23, 2017 Official word from the Admin Team is "This is something we are aware of and are working towards a solution but there is not a timeline for it." Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
SashaPro Posted December 10, 2017 Share Posted December 10, 2017 Hi guys! Listen - well at such temperature of the motherboard there would be a fire, is not it? See what a fantastic figure! Link to comment Share on other sites More sharing options...
Moderators mta Posted December 10, 2017 Moderators Share Posted December 10, 2017 g'day @SashaPro, welcome to the forums. agreed, which is why you can dismiss it straight away. if there was an award, I think you have the highest so far, so Congrats! Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
Causticspit Posted December 10, 2017 Share Posted December 10, 2017 Why are these temperature readings taking SOOOOOoooo long to fix in Speccy? Link to comment Share on other sites More sharing options...
Moderators mta Posted December 10, 2017 Moderators Share Posted December 10, 2017 we (Moderators) do not know, the only word from high is what has already been posted above. (sorry - can't even tell you the post number since this forum software was updated and that feature turned off!) personally, based on the duration of the issue, I can only surmise that the problem is either; bigger than Ben-Hur, not effecting program usage, no spare resource to investigate, investigated but don't know how to fix, very, very, low priority, all the above. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
