rabbit Posted November 27, 2014 Share Posted November 27, 2014 Windows 7 Tried to uninstall CC today (not because of new UI). I noticed that this new version did not show up in Revo Uninstaller. Thinking that was odd so I checked Control Panel and it was there. I decided to uninstall/reinstall; but going through Control Panel it only removes the Control Panel entry. CC remains fully installed and functioning. Nothing else has happened. IF this is something as a result of the new version of CC, then that really pisses me off. BTW, I have been a CC user almost since it was first introduced, and have been happy and encouraged others to use it. But I fully expect any program I use to allow me to remove it without problem. Please advise. Thanks. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted November 27, 2014 Moderators Share Posted November 27, 2014 Did you have monitoring on? Try reinstalling CCleaner over the top of what you have and then boot into safe mode and uninstall from control panel that way. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 27, 2014 Moderators Share Posted November 27, 2014 You can also run the Uninstaller (.exe file) directly from the folder where CCleaner is installed. Link to comment Share on other sites More sharing options...
