jimmy111 Posted June 19, 2013 Share Posted June 19, 2013 When i try to uninstall ie9 from windows update I get this error message: not all of the updates were successfully uninstalled. I have tried everything to fix this but nothing works. I don't want to reformat my hard drive and reinstall windows 7 to fix this but I don't know what else to do. Anyone else ever had this problem and fixed it without reinstalling windows again? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 20, 2013 Moderators Share Posted June 20, 2013 Have you by chance ever used in CCleaner: Cleaner > Advanced > Hotfix Uninstallers If so that "could be the issue". Edit: Here's a search I did: remove ie9 Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 20, 2013 Share Posted June 20, 2013 if you want to "remove" IE you have to add/remove windows components (windows features on Windows 7) It wont actually "remove" IE it will just downgrade it. IE is just an interface for a part of the windows engine called trident. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted June 20, 2013 Moderators Share Posted June 20, 2013 Or you may have to make sure you have selected 'view installed updates' in Programs and Features and uninstall it from there. See here for different ways and discussion. http://social.technet.microsoft.com/Forums/windows/en-US/bde89cbf-f926-47b6-8e85-c76196747ba9/downgrade-ie9-to-ie8-windows-7 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 20, 2013 Share Posted June 20, 2013 My experience with removing IE as a windows component is it disappearing, then readding it will return the version windows shipped with (6 for windows xp, etc) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators mta Posted June 20, 2013 Moderators Share Posted June 20, 2013 or thinking from left field, maybe reinstall IE9 , reboot, then try un-installing again. that should fix any problems with the current install, at least enough to allow you to remove it. DON"T remove through CC, best go the way @Winapp2.ini suggests for Win7; Start, Control Panel, Programs & Features, View Installed Updates, in the Microsoft Windows are you should find IE9. Reboot and that will finish the install of IE8. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
