noobkiller5921 Posted December 9, 2012 Share Posted December 9, 2012 Hi I Have speccy Version 1.19.411 Istalled On My Computer when I load speccy it analizes cpu, ram and motherboard then speccy displays and error message "LoadLibary Faild With Error 126: The specfied Module Could Not Be Found." Can Someone Please Help. I Am Running Windows 8 Pro 64-Bit OS. I Have Uninstalled The Software And Reinstalled It And I Still Recieve The Error Message. Thanks Shawn NoobKiller5921 Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 10, 2012 Moderators Share Posted December 10, 2012 please run Speccy in Debug mode http://www.piriform.com/docs/speccy/troubleshooting-speccy/running-speccy-in-debug-mode then post the log here at this thread as an attachment, you may have to change its extension from .log to .txt ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
noobkiller5921 Posted December 10, 2012 Author Share Posted December 10, 2012 Hello Nergal, When I Run Speccy In Debug Mode I Get The Same Error Message Plus A Message That Says No Update Advabile I Have Attached A Screen Shot. Do You Have Any Other Ideas. NoobKiller5921 Link to comment Share on other sites More sharing options...
Willy2 Posted December 10, 2012 Share Posted December 10, 2012 Try a program called "Windows Repair" (WR) (www.tweaking.com) and run it with - at least - the box called "Repair WMI" ticked. WR can solve a significant amount of problems. If it helps you then post a reply in this thread. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 10, 2012 Moderators Share Posted December 10, 2012 (edited) Hello Nergal, When I Run Speccy In Debug Mode I Get The Same Error Message Plus A Message That Says No Update Advabile I Have Attached A Screen Shot. Do You Have Any Other Ideas. I expect you to get the same result, and debug mode always checks for updates. Please attach the created logfile from the debug as an attachment @Willy, I'm not sure that's his issue as other components load, is there any harm in running the utility if wmi functions? Edited December 10, 2012 by Nergal ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
noobkiller5921 Posted December 10, 2012 Author Share Posted December 10, 2012 Hi Nergal, i can get any log file everytime i load speccy even in debug mode i get the error message the the program closes i gone to try that window repair thing. i will post back later and let you know what happens thanks Shawn NoobKiller5921 Link to comment Share on other sites More sharing options...
nodles Posted December 10, 2012 Share Posted December 10, 2012 Not Willie, but it shouldn't do any harm. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted December 10, 2012 Moderators Share Posted December 10, 2012 See here http://www.withinwin...rror-126-redux/ and here http://answers.microsoft.com/en-us/windows/forum/windows_vista-windows_programs/error-loadlibrary-failed-with-error-126-the-module/c5b67473-00f8-4e4a-b8a5-f7f9c619c3d9?msgId=1ed067ec-ff2c-4e5a-8fcd-1a0b6f2ac00a Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
noobkiller5921 Posted December 10, 2012 Author Share Posted December 10, 2012 Hey I Tried The Windows Repair It Did Not Fix The Issue But It Fix Some Other Issues I was Having lol. is The Anything Else I Can Try nergal? and hazlenut i am sorry but i am not downloading that simple .reg file i dont trust it but thanks. Shawn NoobKiller5921 Link to comment Share on other sites More sharing options...
Moderators DennisD Posted December 10, 2012 Moderators Share Posted December 10, 2012 Hi Shawn, and welcome to the forum. I found the same fix that hazel links to, and it seems to have fixed an awful lot of those errors, and If you already have "Windows Repair", you could use it to back up the registry, and restore it if the reg fix doesn't work. I would suggest at least having a look at the location the reg file is targeted at, and this is the actual contents of that reg file ... Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000] "OpenGLVendorName"=hex(7):61,00,74,00,69,00,6f,00,36,00,61,00,78,00,78,00,2e,\ 00,64,00,6c,00,6c,00,00,00,61,00,74,00,69,00,6f,00,36,00,61,00,78,00,78,00,\ 2e,00,64,00,6c,00,6c,00,00,00,00,00 It apparently puts right what is an error in the "OpenGLVendorName" entry. All this ties in with "method 3" of hazels 2nd link, and one of the links I found last night, which shows very clearly in screenshots what the problem is supposed to be. And a copy of the same reg fix. http://servicecore.i...indows-systems/ You should at least fire up regedit, and check out that registry location, and see what you have in there. An alternative to backing up the registry would be to "export" the original entry to a safe location, and if nothing changes after trying the fix, then just merge the exported original entry back into the registry. Your choice of course Shawn. Link to comment Share on other sites More sharing options...
noobkiller5921 Posted December 10, 2012 Author Share Posted December 10, 2012 Thank you All For Your Help My speccy Is Working!! And Thanks Hazelnut and DennisD For Providing The Fix. Happy Holidays Everyone! Shawn NoobKiller5921 Link to comment Share on other sites More sharing options...
Willy2 Posted December 10, 2012 Share Posted December 10, 2012 @Noobkiller: "Registry Backup" (www.Tweaking.com) is a great tool to backup the registry. No need to use "Windows Repair" when one only wants to backup the registry. I am glad "Window Repair" fixed a number of problems. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
Moderators DennisD Posted December 11, 2012 Moderators Share Posted December 11, 2012 Thank you All For Your Help My speccy Is Working!! And Thanks Hazelnut and DennisD For Providing The Fix. Happy Holidays Everyone! Shawn Same to you Shawn. Pleased you fixed it. Link to comment Share on other sites More sharing options...
