ladt25 Posted November 17, 2011 Share Posted November 17, 2011 It doesn't seem to want to let me post anything. Link to comment Share on other sites More sharing options...
ladt25 Posted November 17, 2011 Author Share Posted November 17, 2011 OK now it does! Basically I analyzed the drive and it came up as about 41% fragmented, but also it appeared to be in two seperate groups of blocks. The bottom half remained mostly fragmented after running it - also more space is being used. I would include a screenshot but it doesn't seem to want to let me do that. I just don't understand why it's split in two. Link to comment Share on other sites More sharing options...
Alan_B Posted November 17, 2011 Share Posted November 17, 2011 Everything died today. New Servers on and lots of loose ends to pick up. Screenshots were O.K. yesterday. Try again tomorrow. Link to comment Share on other sites More sharing options...
kroozer Posted November 17, 2011 Share Posted November 17, 2011 I would include a screenshot but it doesn't seem to want to let me do that. Try posting a screenie thru a free hosting site like postimage or imageshack. Registration not required. Link to comment Share on other sites More sharing options...
ladt25 Posted November 18, 2011 Author Share Posted November 18, 2011 http://s12.postimage.org/l0u82vtp9/defrag.jpg' alt='defrag.jpg'> image hosting jpg[/img] Just did 'Check Drive for Errors' and even though it came out with no errors, it sent the used space back down to what it was. Link to comment Share on other sites More sharing options...
ladt25 Posted November 18, 2011 Author Share Posted November 18, 2011 Whoops, ignore that first bit! I think I'm just going to leave it now. The part that remains fragmented seems to be all system volume info which I know it won't do. Link to comment Share on other sites More sharing options...
ladt25 Posted November 18, 2011 Author Share Posted November 18, 2011 http://postimage.org/image/4d2q0dyxl/ Link to screenshot Link to comment Share on other sites More sharing options...
kroozer Posted November 18, 2011 Share Posted November 18, 2011 Thanks for the image. The hot link posting code I extracted from your code on reply #5 is ► [img=http://s12.postimage.org/l0u82vtp9/defrag.jpg] Some free space is lost cos Windows increases your Sys Vol Info when defragging partitions. By using CCleaner's System Restore Management you can delete an old Restore Point to compensate for lost space. You have only 4% frag. Run a Boot Time Defrag to see if you can get it lower. I just don't understand why it's split in two. On smaller partitions Windows always places Sys Vol Info files near the disk center. They don't need to be towards the beginning cos they are rarely needed. Link to comment Share on other sites More sharing options...
ladt25 Posted November 19, 2011 Author Share Posted November 19, 2011 OK, thanks a lot for your help! Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 22, 2011 Moderators Share Posted November 22, 2011 What you have is [img=[url=http://postimage.org/][img]http://s12.postimage.org/l0u82vtp9/defrag.jpg][/url] [url="http://postimage.org/"]image hosting jpg[/url][/img] what you actually want is [img=http://s12.postimage.org/l0u82vtp9/defrag.jpg] ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
