ident Posted September 3, 2010 Share Posted September 3, 2010 Should include startup items. (deletion) No fate but what we make Link to comment Share on other sites More sharing options...
mr don Posted September 5, 2010 Share Posted September 5, 2010 Should include startup items. (deletion) Usually, you have what sounds like a good suggestion. But what the? I am confused! Should include startup items? What does that mean? CCleaner already shows startup items... Did you mean something else? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 5, 2010 Moderators Share Posted September 5, 2010 I think he's saying that if options>Advanced Hide Warning Messages is checked that CCleaner should not ask "This will permanently remove startup entries. Are you sure you want to do this?" when a startup item is highlighted and the delete button is pressed. I worry about said idea because it would be easy to press delete accidentally instead of disable, and there is no turning back from this without the dialog. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
mr don Posted September 5, 2010 Share Posted September 5, 2010 I think he's saying that if options>Advanced Hide Warning Messages is checked that CCleaner should not ask "This will permanently remove startup entries. Are you sure you want to do this?" when a startup item is highlighted and the delete button is pressed. I worry about said idea because it would be easy to press delete accidentally instead of disable, and there is no turning back from this without the dialog. I agree. It would be easy to slip while you are eating your cookies & hit the wrong thing, or someone scare you & you click the button. Having that 1 prompt would be something that isn't necessary, but it helps prevent something from being deleted that you may want back. The way around this, if this were implemented, would be to automatically backup to a .reg key the path that was deleted so it can be restored if necessary. Link to comment Share on other sites More sharing options...
ident Posted September 5, 2010 Author Share Posted September 5, 2010 I think he's saying that if options>Advanced Hide Warning Messages is checked that CCleaner should not ask "This will permanently remove startup entries. Are you sure you want to do this?" when a startup item is highlighted and the delete button is pressed. I worry about said idea because it would be easy to press delete accidentally instead of disable, and there is no turning back from this without the dialog. Press delete accidental? That would be the users fault for having hide warning messages checked, and key word "There" fault. If warning messages is checked then ccleaner assumes you know what you are doing. Linux for example, it assumes you know what you are doing. I know very much what i'm, doing. I have that checked because i dont need warning messages. No fate but what we make Link to comment Share on other sites More sharing options...
ishan_rulz Posted September 5, 2010 Share Posted September 5, 2010 +1 Simplicity is hard. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 6, 2010 Moderators Share Posted September 6, 2010 Hi, i recently edited the startup menu on CCleaner and accidentally deleted the ones i disabled and was wondering if i can get the original startup programs back as some parts of my laptop are not working as they should be. Thanks in advance You were saying? (and remeber that is WITH the warning message) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
ident Posted September 6, 2010 Author Share Posted September 6, 2010 I'm still saying what my thread topic is. That is the users fault. Not ccleaner. With out a warning that particular user would of still messed things up. No fate but what we make Link to comment Share on other sites More sharing options...
Alan_B Posted September 7, 2010 Share Posted September 7, 2010 Because he was given a warning the damage was his fault and he cannot tarnish the reputation of CCleaner as being as "safe" cleaner. Had CCleaner NOT given a warning it is still his fault for doing what he didn't oughta, but CCleaner would be guilty of enabling a naive user to wonder without warning into destruction. Regards Alan Link to comment Share on other sites More sharing options...
ishan_rulz Posted September 7, 2010 Share Posted September 7, 2010 Because he was given a warning the damage was his fault and he cannot tarnish the reputation of CCleaner as being as "safe" cleaner. Had CCleaner NOT given a warning it is still his fault for doing what he didn't oughta, but CCleaner would be guilty of enabling a naive user to wonder without warning into destruction. Regards Alan true, but the "Hide warning" option is unchecked by default. An user would only check it when he knows what he is doing. Simplicity is hard. Link to comment Share on other sites More sharing options...
ident Posted September 11, 2010 Author Share Posted September 11, 2010 I would also be interested to know which warning messages it is meant to hide. No fate but what we make Link to comment Share on other sites More sharing options...
Moderators Augeas Posted September 11, 2010 Moderators Share Posted September 11, 2010 According to the documentation, Hide Warning Messages is 'Useful if you want to run CCleaner in silent or batch mode.' So maybe it applies only to data removal. I've no idea if you could remove startup entries in silent mode as I've never tried it, and it doesn't seem to be the sort of thing I'd want to try. Link to comment Share on other sites More sharing options...
ident Posted September 11, 2010 Author Share Posted September 11, 2010 But can you actually think of any particular message it hides. No fate but what we make Link to comment Share on other sites More sharing options...
Moderators Augeas Posted September 11, 2010 Moderators Share Posted September 11, 2010 Well, blow me down with whatever. I've just ticked the Hide Warning Messages and attempted to clean some data and the warning message still appears. So no, I've no idea what this option does. Link to comment Share on other sites More sharing options...
ident Posted September 11, 2010 Author Share Posted September 11, 2010 My point, After a fresh format the other day i ticked "hide warning messages" and instantly get on cleaning "Firefox needs to be closed" "This will permanently remove data from your computer" etc so what the hell does it hide lol No fate but what we make Link to comment Share on other sites More sharing options...
