Eli Posted April 2, 2010 Share Posted April 2, 2010 Hi Did any of you encounter a shut down issue with IE 7 and IE 7 pro addon? When I activate the browser ,as soon as it tries to open an internet connection, it shuts down the machine. How do I know that this is an interrelation issue? I uninstalled IE7 pro....and everything is normal now. I`m interested to know if it is only here or some of you happen to encounter this same problem as well. Thanks OS : MS windows XP pro sp3 Processor : AMD Athlon 64x2 Dual core 3800, 2009Mhz.Mother board : Gygabyte M61 PM-S2 Ram : 3GBDisk space : 649.05 GB Default browser: FirefoxProtection : Sandboxie, MBam free version Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 3, 2010 Moderators Share Posted April 3, 2010 I'm using IE8 and an older version of IE7 Pro (version 2.4.6) and have no shutdown issue. Maybe your IE7 Pro if it's the newest version doesn't properly support old IE7 anymore, don't know for sure however it's a possibility. Link to comment Share on other sites More sharing options...
Anomaly Posted April 3, 2010 Share Posted April 3, 2010 I'm using IE8 and an older version of IE7 Pro (version 2.4.6) and have no shutdown issue. I'm interested to know are you using IE8 on XP? If so have you noticed any problems? I have read many reports of IE8 messing up on XP? I recently up graded a machine to Windows 7 and IE8 runs very snappy on there. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted April 3, 2010 Moderators Share Posted April 3, 2010 Just to let you know Anomaly, I have had no problems using IE8 on XP. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Anomaly Posted April 3, 2010 Share Posted April 3, 2010 Just to let you know Anomaly, I have had no problems using IE8 on XP. Thanks and good to hear because after using IE8 on Windows 7 I would like to add it to my XP computer since that computer will not be getting a Windows 7 update. Did you download IE8 through Windows Update or did you download it from the IE8 site and install that way? Did you do anything different in your install? Link to comment Share on other sites More sharing options...
Eli Posted April 3, 2010 Author Share Posted April 3, 2010 I'm using IE8 and an older version of IE7 Pro (version 2.4.6) and have no shutdown issue. Maybe your IE7 Pro if it's the newest version doesn't properly support old IE7 anymore, don't know for sure however it's a possibility. Hi Andavari Please see the following(taken from here): http://www.ie7pro.com/download.php?language=en System requirements In order to use IE7Pro, you must have one of the following operating systems and browsers installed: 1. 64 MB of RAM 2. 6 MB of free disk space 3. Microsoft WindowsNT /2000 /XP /2003 /Vista 4. Support Internet Explorer 6.0/7.0 and above OS : MS windows XP pro sp3 Processor : AMD Athlon 64x2 Dual core 3800, 2009Mhz.Mother board : Gygabyte M61 PM-S2 Ram : 3GBDisk space : 649.05 GB Default browser: FirefoxProtection : Sandboxie, MBam free version Link to comment Share on other sites More sharing options...
Eli Posted April 3, 2010 Author Share Posted April 3, 2010 Just to let you know Anomaly, I have had no problems using IE8 on XP. Hi hazelnut How is IE8 compared to IE7 when dealing with resources and effectiveness of browsing(on Win xp pro sp3) ? OS : MS windows XP pro sp3 Processor : AMD Athlon 64x2 Dual core 3800, 2009Mhz.Mother board : Gygabyte M61 PM-S2 Ram : 3GBDisk space : 649.05 GB Default browser: FirefoxProtection : Sandboxie, MBam free version Link to comment Share on other sites More sharing options...
Anomaly Posted April 3, 2010 Share Posted April 3, 2010 Hi Andavari Please see the following(taken from here): http://www.ie7pro.com/download.php?language=en System requirements In order to use IE7Pro, you must have one of the following operating systems and browsers installed: 1. 64 MB of RAM 2. 6 MB of free disk space 3. Microsoft WindowsNT /2000 /XP /2003 /Vista 4. Support Internet Explorer 6.0/7.0 and above So IE7 Pro does not work on Windows 7? Link to comment Share on other sites More sharing options...
