Nymbous Posted July 23, 2009 Share Posted July 23, 2009 When i try to delete the old system recovery points it gives me " Error 1722 - The RPC server is unavailable." I just recently turned off some system services under control panel > administrative tools > services, i may have turned one off that is causing this error. Any help would be appreciated Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 24, 2009 Moderators Share Posted July 24, 2009 Try restarting the System Restore Service and see if that helps, you can do that via a command prompt too: net start "System Restore Service" Link to comment Share on other sites More sharing options...
Nymbous Posted July 24, 2009 Author Share Posted July 24, 2009 i turned on the service and restarted it. it started up fine but still the same problem. Will i be gaining a significant amount of space and performance by clearing out the dozen or more save that system restore has in it? Link to comment Share on other sites More sharing options...
aqua Posted July 24, 2009 Share Posted July 24, 2009 what i do is to turn off sytem restore like once a week and i gain like 4-500mg..but for example if you find a trojan or malware,you have to turn off system restore,then chech it again for gaining performance you can follow black viper sites suggestions.,,also from shields up..advice to "untick" file and printer sharing,client for microsoft network. also i benefit a lot from defraging my registry with a free program from winaso -winaso regdefrag- is really good. good luck Link to comment Share on other sites More sharing options...
Moderators Augeas Posted July 24, 2009 Moderators Share Posted July 24, 2009 Perhaps if the error is 'The RPC server is unavailable' you could try turning on the Remote Procedure Call service. One of its long list of dependencies is the System Restore Service - and another is the Secrity Center, which you may wish to have enabled. Link to comment Share on other sites More sharing options...
