User000 Posted July 10, 2007 Share Posted July 10, 2007 Hi, i downloaded the the av from the link in ridgys internet rot site, then when i clcik on it it says windows installer cannot open this blah blah, so i went and used the clean up ulitilite and even redownloaded and installed the windows installer, and i still get the same message, i can install any other .msi file fine, just not aol av, any ideas? Thanks. I really want to use, this as i heard kasperky is one of the best! heres a screenshot Link to comment Share on other sites More sharing options...
fireryone Posted July 10, 2007 Share Posted July 10, 2007 Try re-downloading the AOL AV, as it probably got corrupted during download. Nice Wallpaper by the way. fireryone Link to comment Share on other sites More sharing options...
User000 Posted July 10, 2007 Author Share Posted July 10, 2007 Try re-downloading the AOL AV, as it probably got corrupted during download. Nice Wallpaper by the way. Thanks, but i have downloaded and tryed it about 10 times now and same problem. any other msi works fine. Just not this one, is it just me? Does someone have a working one? and heres my wall paper if your interested in it fire Link to comment Share on other sites More sharing options...
fireryone Posted July 10, 2007 Share Posted July 10, 2007 Have you tried downloading from a different site? Try Download.com http://www.download.com/AOL-Active-Virus-S...4-10568703.html Thanks for the wallpaper fireryone Link to comment Share on other sites More sharing options...
User000 Posted July 10, 2007 Author Share Posted July 10, 2007 Have you tried downloading from a different site? Try Download.com http://www.download.com/AOL-Active-Virus-S...4-10568703.html Thanks for the wallpaper clicking download on download.com redirects to the same site. thus the same problem occurs. Link to comment Share on other sites More sharing options...
User000 Posted July 10, 2007 Author Share Posted July 10, 2007 and i just did a system restore to before i ran baku, clean up ulitlie, etc and i still have the same problem! Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted July 11, 2007 Moderators Share Posted July 11, 2007 Just read this on a blog somewhere During the installation, AVS also checks if you have another anti-virus software that could cause conflicts and gives the option to uninstall it. Without uninstalling other detected anti-virus software you cannot install Active Virus Shield. Not sure if it will help you . EDIT... you are not alone http://www.wilderssecurity.com/showthread.php?t=179768 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Humpty Posted July 11, 2007 Share Posted July 11, 2007 You could try the Windows installer below.May help? DescriptionThe Microsoft Windows Installer is an 'application installation and configuration service'. This means that it is used for installing programs on your computer. Some software requires this latest download before you can install it. In effect, this becomes a two step process. First you download the Windows Installer and run it (restart your computer). Then run your software's installation program (yes, there is some degree of Microsoft kookiness that requires you to install an installation program before you can install the program you actually want). Windows installer Link to comment Share on other sites More sharing options...
User000 Posted July 11, 2007 Author Share Posted July 11, 2007 i have the latest windows installer ive uninstalle dmy other av. now im downloading the slightly outdated version from neowin and major geeks to see if i can install that and then update to the latest version from that. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted July 11, 2007 Moderators Share Posted July 11, 2007 If you don't have any luck, have a read of post number 8 here, http://forum.kaspersky.com/index.php?showtopic=24978 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
User000 Posted July 11, 2007 Author Share Posted July 11, 2007 If you don't have any luck, have a read of post number 8 here, http://forum.kaspersky.com/index.php?showtopic=24978 thanks, im trying the 25 link right now. Link to comment Share on other sites More sharing options...
User000 Posted July 11, 2007 Author Share Posted July 11, 2007 This is a big probelm now, taken from a forum "elite" there this will help many other people who have the smae problem as me: ok, i downloaded that msi myself. looks like they replaced the msi with a new version (6.0.2.621, previously was 6.0.0.308), unfortunatly the uploaded file is incomplete (so it's not a valid installation file). That one is the one which works: http://download.nullsoft.com/avs/AVS_v25.exe Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted July 11, 2007 Moderators Share Posted July 11, 2007 Great that you got the working one now. Lets hope they put this mess right. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Humpty Posted July 11, 2007 Share Posted July 11, 2007 Thanks for that link to the Kaspersky forum Hazel. Actually managed to install Active Shield on my Vista Ultimate drive using that installer. The original installer I downloaded which was "supposedly Vista compatible" was a 13 or so meg download whereas the the one from the link is 18 meg. The first installer worked fine on XP but just wouldn't install on Vista and I just thought, oh well another app that doesnt like Vista. Link to comment Share on other sites More sharing options...
