Parvez Posted February 17, 2007 Share Posted February 17, 2007 This is how my screen looks: and this is how it was before: http://img462.imageshack.us/my.php?image=sadsadsx7.jpg how do i fix it? the icon looks werid.. there are black color behind the icons and it's kind of laggy. Any help? please thanks! Link to comment Share on other sites More sharing options...
JDPower Posted February 18, 2007 Share Posted February 18, 2007 Try going to Control Panel>System>Advanced>Performance Settings. Under the 'Visual Effects' tab tick 'Use drop shadows for icon labels on the desktop' Link to comment Share on other sites More sharing options...
Humpty Posted February 18, 2007 Share Posted February 18, 2007 Try this.May help. Display properties - Desktop tab - Customize Desktop - Web tab - untick Lock desktop items then apply/ok out. Link to comment Share on other sites More sharing options...
Parvez Posted February 18, 2007 Author Share Posted February 18, 2007 Thanks for the help. I appreciate it. They didn't work at all. It was the same. I downloaded MS Tweak UI and did a Rebuild on the icons several times and downloaded a .reg tweak from Kelly's Reg and then restarted the computer. It's working completely fine now though. Thank you Link to comment Share on other sites More sharing options...
