whiskeychick504 Posted May 27, 2023 Share Posted May 27, 2023 PLEASE HELP!!!!! Im currently using an Android that was loaned to me by a friend after my iphone was stolen. I'm getting used to it for the most part, but the biggest problem that I'm having right now is that I can't use tap to pay because the phone is jailbroken & rooted. In one of my searches CCleaner was recommended for helping me with reversing this so that I can use the tap to pay feature. I would appreciate any help with this, whether it's advice with this app, another app, or something else altogether. Thanks!!! Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 27, 2023 Moderators Share Posted May 27, 2023 No ccleaner cannot help unroot. I suggest the forum for your device on xda https://forum.xda-developers.com/ . It should be easy for them to walk you through unrooting. Really a factory reset is probably all you need. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
whiskeychick504 Posted May 27, 2023 Author Share Posted May 27, 2023 (edited) Thanks so much!!!! What do I do if I don't see my phone listed? It's a motorola one 5G ace, which I'm sure is a bottom of the barrel phone to begin with. I was given an iphone,, but I have to get into it, it was their dads & he passed away, but no one knows his passcode to get into the phone or his icloud password....it's always something, but I'm just grateful to have something to attempt to use. Edited May 27, 2023 by whiskeychick504 Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 27, 2023 Moderators Share Posted May 27, 2023 9 hours ago, whiskeychick504 said: What do I do if I don't see my phone listed? It's a motorola one 5G ace, which I'm sure is a bottom of the barrel phone to begin with. https://forum.xda-developers.com/c/moto-g-5g-motorola-one-5g-ace.11863/ ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
redwolfe_98 Posted May 27, 2023 Share Posted May 27, 2023 https://www.androidauthority.com/how-to-unroot-android-phone-tablet-652905/ Link to comment Share on other sites More sharing options...
