ElleBee Posted May 19, 2022 Share Posted May 19, 2022 (edited) Can someone please advise why recent C Cleaner Update v5. 92.9652 skips Edge and internet Explorer clean and no longer empties recycle bin? There were no issues prior to this update. They have all been ticked as per usual. Edited May 19, 2022 by ElleBee grammar error Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 19, 2022 Moderators Share Posted May 19, 2022 (edited) Latest ccleaner is version 6. Ccleaner skips edge because at some point you told it not to show you that edge needs to be closed, and something (some software that is running, or even edge itself, when you do your clean) is keeping edge open. Make sure in edge that fast startup and run in the background are turned off. In ccleaner there's an option to turn warning messages back on, but i can't remember where. Empty recycle bin, is a harder one. Perhaps the only older than 24 hours got checked. Are the files still in the bin or is it just that ccleaner reports the same size after a clean? Edited May 19, 2022 by Nergal ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
