jquinn33 Posted September 28, 2021 Share Posted September 28, 2021 We've been using CCleaner for several years and anytime a notification would come up letting me know about a particular action such as "Browser cleaned," it would fade out a few seconds later, which was great so as not to cover up part of the application windows I was working in underneath the CCleaner notification. Now the notifications stay up until I manually close each one which is annoying. Is there a way to go back to having all notifications fade out after they come up? Link to comment Share on other sites More sharing options...
Moderators nukecad Posted September 28, 2021 Moderators Share Posted September 28, 2021 You could simply set it to clean the browser(s) on closing without giving the notification, you can set different options for each browser. Unless you want to see them of course. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 28, 2021 Moderators Share Posted September 28, 2021 Better yet, i'll giveyou the fix. Next to the close x is a thumbtack click it and the notifications will fade as they once did. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
jquinn33 Posted September 29, 2021 Author Share Posted September 29, 2021 EXCELLENT! Thank you for both responses Nukecad and Nergal! I've employed both suggestions. So THAT'S what that thumbtack is for!! Ha!! Thank you again! :) Link to comment Share on other sites More sharing options...
