squeakyclean Posted December 20, 2014 Share Posted December 20, 2014 What is up with the lock symbol??. I thought system monitoring was free?. Although I can tick the box. Will it work?. Could someone please explain this. Thank. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted December 20, 2014 Moderators Share Posted December 20, 2014 Please see here https://www.piriform.com/docs/ccleaner/ccleaner-settings/changing-monitoring-settings-ccleaner-free Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
squeakyclean Posted December 20, 2014 Author Share Posted December 20, 2014 OK. Thanks. So in other words I just tick the enable system monitoring box. But it still doesn' t explain the the pro lock symbol underneath that. Thanks. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted December 20, 2014 Moderators Share Posted December 20, 2014 Here is the documentation for monitoring functions using CCleaner Professional Version http://www.piriform.com/docs/ccleaner/ccleaner-settings/changing-monitoring-settings-ccleaner-professional/system-monitoring Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 21, 2014 Moderators Share Posted December 21, 2014 Are you using the portable version ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
squeakyclean Posted December 30, 2014 Author Share Posted December 30, 2014 (edited) Sorry folks. But I migrated to [removed competing product name]. Works how it should. No hassle. Thanks though for the non answers. Edited December 30, 2014 by Andavari removed competing product name Link to comment Share on other sites More sharing options...
