menet Posted April 30, 2013 Share Posted April 30, 2013 i was thinking maybe you can put a stronger engine so the program can run faster specifically on driver wiper Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 30, 2013 Share Posted April 30, 2013 It can only wipe as fast as your drive can write data. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 1, 2013 Moderators Share Posted May 1, 2013 obviously you must be aware the your request mean absolutely nothing in coding terms. There's no such beast as a "software engine" that "drives" the time of a program's processing; at least nit in anyway that is suggested by this thread. Especially something hardware dependent as writing a bunch of data (times the number of wipes you asked for) then erasing said data (times the number of wipes you asked for yet again) in an alternating manner. so if you're Doing Wipe Freespace on a (relatively tiny in today's hardware) 10 GB drive with 6 GB free ccleaner (any wiper worth a spit) must write a file filled with 1 byte/character characters of 6 GB (roughly 6,442,450,944 characters) At the speed your hard drive supports and the amount of Ram/cache your computer and/or harddrive have. It then Deletes that/those files. Lets say you're "very security conscious" so you chose Guzman35. So we multiply the 6,442,450,944 by 35 to get 225,485,783,040 characters. enjoy trying to type that many characters faster and have the computer process it ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
