Sandman192 Posted May 1, 2012 Share Posted May 1, 2012 I heard that it doesn't clean SSD's right. Male it work on those. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 1, 2012 Moderators Share Posted May 1, 2012 No that is not the case, I believe whomever told you that was attemping to inform you that you should not use Wipe Free Space nor The Disk Wiper Utility on the SSD ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Augeas Posted May 1, 2012 Moderators Share Posted May 1, 2012 Nor secure file deletion, but the Cleaner and Registry sections are fine. Link to comment Share on other sites More sharing options...
