ssanchez Posted October 4, 2011 Share Posted October 4, 2011 Hello world, Not sure if this is the right forum category to post this. Here is my issue. When I run CCleaner I get BSOD. SYSTEM_SERVICE_EXCEPTION The funny thing is that I loged in to a different profile and ran the scan and no issues ran beautifully. any help/suggestions? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted October 4, 2011 Share Posted October 4, 2011 Which operation system are you running? Is the affected user account an adminstrator? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Ressot Posted October 4, 2011 Share Posted October 4, 2011 I have the same problem, using Windows 7 Home Premium 64 Bit. Link to comment Share on other sites More sharing options...
Arowen Posted October 5, 2011 Share Posted October 5, 2011 I have gotten BSOD via the last two updates of vers. 3,11. Uninstalled both times, reinstalled vers. 3.10, works fine... I have attached a .zip of the mem dump from the newest version that crashed. I am using Windows 7 Home Premium 64 bit WER-62728-0.sysdata.xml.zip Always do the right thing...this will gratify most people and astonish the rest... Link to comment Share on other sites More sharing options...
Tr3bg0D Posted October 5, 2011 Share Posted October 5, 2011 interesting...3.11.1550 has been working fine on all my systems Link to comment Share on other sites More sharing options...
Winapp2.ini Posted October 5, 2011 Share Posted October 5, 2011 Well I'm sure the devs will take a look at the file and fix that up in a future version. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Arowen Posted October 25, 2011 Share Posted October 25, 2011 After having installed both versions of 3.11 and experienced BSOD's on both, I thought I'd try out the newest version, 3.12... same results. The latest stable version for me has been 3.10.1525. I haven't done any major changes to my system in the last couple of months, so I can't figure out the issue. This is quite frustrating, as I have been an avid CCleaner user for years (I remember when it was called "CrapCleaner")... I can't understand why I haven't been able to use the last three updates without crashing my system, since over the years I have routinely installed literally dozens upon dozens with no problem. If anyone can help, please do. I am running Windows 7 Home Premium, 64 bit, and have attached the crash file via a .zip 10-25-2011 After new CCleaner install.zip Always do the right thing...this will gratify most people and astonish the rest... Link to comment Share on other sites More sharing options...
Alan_B Posted October 25, 2011 Share Posted October 25, 2011 Does this apply to everyone, i.e. a BSOD caused by Analyse as opposed to Clean ? ran the scan and no issues ran beautifully. If analyse causes the crash I would suggest some problem is stuck in the registry. Try the Portable version of CCleaner which you can unzip to a different folder if you wish. Link to comment Share on other sites More sharing options...
Guest MrRon Posted October 25, 2011 Share Posted October 25, 2011 Thanks, we'll have a look at these. Link to comment Share on other sites More sharing options...
Jhawk Posted December 29, 2011 Share Posted December 29, 2011 Yea, I've just started getting the same error message. Strange...happened a while back, but then straightened out on its own. Thanks for looking into it. EDIT: Issue seems to have resolved itself. CC running smooth and doing its normal job. Link to comment Share on other sites More sharing options...
Selvan Posted December 30, 2011 Share Posted December 30, 2011 No issuess here with v3.14.1616 (64b), or any other previous versions, on Win 7 HP 64B SP1. If in your shoes, I would: make a complete backup of the disk uninstall CC reboot delete all found in C: or any other drive delete all found in the registry (keys, values, & data after very careful review) reboot re-install CC and hope all is good (but only after you are certain all traces of CC is gone) If not, restore the disk backup you created and wait for the develepores. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 2, 2012 Moderators Share Posted January 2, 2012 That seems to be a bit of a sledge hammer for an occasional (and not 100% recreatable) problem, you must work for some sort of tech support line (j.k. but it really does seem overkill for an occasional BSOD) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
