trium 0 Posted February 27, 2011 Share Posted February 27, 2011 hallo leute, ich habe eine Geforce 4200 Ti in meinem Rechner und speccy v 1.08 meint, sie h?tte DirectX Shader Model 1.4 OpenGL Support 1.4 GPU Takt 250 MHz Speicher Takt 500 MHz Das ist falsch! Diese Karte hat nur directx shader model 1.1 und opengl support 1.3. Versions of CCleaner Cloud; Die Toten Hosen - Altes Fieber Ccleaner-->System-Requirements; Ccleaner FAQ´s; Ccleaner builds; Scheduling Ccleaner Free Es ist möglich, keine Fehler zu machen und dennoch zu verlieren. Das ist kein Zeichen von Schwäche. Das ist das Leben -> "Picard" Link to post Share on other sites
Moderators Nergal 0 Posted March 2, 2011 Moderators Share Posted March 2, 2011 Hi people, I have a GeForce Ti 4200 in my machine and speccy v 1.08 thinks she would have DirectX shader model 1.4 OpenGL support 1.4 GPU clock 250 MHz Memory clock 500 MHz This is wrong! This card has only directx shader model 1.1 and opengl support 1.3 Please write in english next time (Use Google Translate if you need to). Also please try the new speecy to see if this is now fixed. Bitte auf Englisch schreiben Sie n?chste Mal (Use Google Translate bei Bedarf) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
