junbug Posted December 20, 2010 Share Posted December 20, 2010 . Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 20, 2010 Moderators Share Posted December 20, 2010 I think CCleaner uses it for the installers, however right clicking the installers and looking at the properties doesn't really reveal anything. It's the same with the Revo Uninstaller setup file. Link to comment Share on other sites More sharing options...
junbug Posted December 20, 2010 Author Share Posted December 20, 2010 . Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 20, 2010 Moderators Share Posted December 20, 2010 CCleaner would clean out that Temp folder location. It's probably just NSIS as the folder name itself is a dead giveaway with "~nsu.tmp", and the Au_.exe I've noticed tons of times before. Allot of installers/uninstallers do that however, even Inno Setup. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 21, 2010 Moderators Share Posted December 21, 2010 most modern install files are made with nsis. Again as stated as au.tmp is in the temp folder it is a temporary file and should be safe to clean. . . probably some installer was not compiled correctly and did not cleanup after. I guess you could looked at the modified date and maybe irk out which installer left it. or just let it delete ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 23, 2010 Moderators Share Posted December 23, 2010 probably some installer was not compiled correctly and did not cleanup after. Also some may actually need a reboot but if running on XP or newer may not ask for one - well I've noticed that a few times. Link to comment Share on other sites More sharing options...
