bandit12345 Posted June 1, 2010 Share Posted June 1, 2010 I created a desktop shortcut for Windows XP SP3. "C:\Program Files\CCleaner\CCleaner.exe" /AUTO /SHUTDOWN Is CCleaner supposed to clean only or clean AND fix registry issues as well? It currently does not fix registry issues on auto shutdown. Link to comment Share on other sites More sharing options...
Aethec Posted June 1, 2010 Share Posted June 1, 2010 It isn't supposed to. The registry cleaner should n e v e r be run automatically. Never. If you want to clean your Registry, check each key, if you know it is something that can be removed, remove it, else don't. But you shouldn't expect any performance boost from Registry cleaning. Piriform French translator Link to comment Share on other sites More sharing options...
Seven_Eleven Posted June 1, 2010 Share Posted June 1, 2010 As far as regards my computers, CCleaner has never done any harm, nevertheless, never trust registry cleaners and never let them run automatically ... check each key, if you know it is something that can be removed, remove it, else don't... (7/11) .!-!-!-!. EsseCi @ Link to comment Share on other sites More sharing options...
