billgates1 Posted March 26, 2008 Share Posted March 26, 2008 Hi, I noticed that the "fix registry" tool in CCleaner has to be run for at least 2-3 times to correct all problems!!! This is because when some items in the registry are removed, other errors appear, so you need a second pass (and sometimes a third pass). I think you should automate this process, by running the tool for more than one time until no problems are found. Link to comment Share on other sites More sharing options...
Moderators Augeas Posted March 26, 2008 Moderators Share Posted March 26, 2008 Yes, this does happen, but I wouldn't want to automate any cleaning actions when dealing with the registry. Link to comment Share on other sites More sharing options...
billgates1 Posted March 26, 2008 Author Share Posted March 26, 2008 Yes, this does happen, but I wouldn't want to automate any cleaning actions when dealing with the registry. OK, you're right, but you could add an option (initially disabled) named, for example, "Enable multi-pass registry cleaning", in a way to leave the choice to enable it to the (expert) user. I think I would use it, because I've used "manual" multipass" for many years and it never generated problems of any sort. Link to comment Share on other sites More sharing options...
amhoyle Posted March 30, 2008 Share Posted March 30, 2008 I think this would be a good suggestion if it ran as follows: 1. You click to run registry scanner. If it finds problems, it prompts you to deal with them. 2. Once it has dealt with the issues you have asked it to, then it automatically scans again, prompts for action - not automatically taking action. This repeats until no issues are found, remembering any errors you have decided not to take action on. elyoh Link to comment Share on other sites More sharing options...
larry39 Posted April 1, 2008 Share Posted April 1, 2008 I think I would use it, because I've used "manual" multipass" for many years and it never generated problems of any sort. I have found CCleaner to be very safe to use but I agree with Augeas about automated cleaning. Just because CCleaner has never generated any problems for you, doesn't mean the next version won't. Link to comment Share on other sites More sharing options...
ignas2526 Posted April 4, 2008 Share Posted April 4, 2008 I agree what this options MUST be added to make CCleaner more powerful! Link to comment Share on other sites More sharing options...
