RHB Posted June 6, 2005 Share Posted June 6, 2005 When I run Issues in CCleaner, I get a columns marked Problems, Data and Registry Key. I don't understand what the problem is and after I run the cleaner, the next time I get the same problems. So can someone explain, please? Many thanks. I use Windows ME. Link to comment Share on other sites More sharing options...
Tarun Posted June 6, 2005 Share Posted June 6, 2005 When I run Issues in CCleaner, I get a columns marked Problems, Data and Registry Key. I don't understand what the problem is and after I run the cleaner, the next time I get the same problems. So can someone explain, please?Many thanks. I use Windows ME. <{POST_SNAPBACK}> Open With... (Application Name) Link to comment Share on other sites More sharing options...
RHB Posted June 6, 2005 Author Share Posted June 6, 2005 When I run Issues in CCleaner, I get a columns marked Problems, Data and Registry Key. I don't understand what the problem is and after I run the cleaner, the next time I get the same problems. So can someone explain, please?Many thanks. I use Windows ME. <{POST_SNAPBACK}> Link to comment Share on other sites More sharing options...
zaphirer Posted June 7, 2005 Share Posted June 7, 2005 First all, don't repeat your same quotes, it's kind of spam-y The issues tab needs to be done several times no matter what your system. Simply right click, "select all" and run the cleaner. Every single time the list will get less and less. You don't have to do until it reaches 0, though. Link to comment Share on other sites More sharing options...
RHB Posted July 4, 2005 Author Share Posted July 4, 2005 First all, don't repeat your same quotes, it's kind of spam-y The issues tab needs to be done several times no matter what your system. Simply right click, "select all" and run the cleaner. Every single time the list will get less and less. You don't have to do until it reaches 0, though. <{POST_SNAPBACK}> Link to comment Share on other sites More sharing options...
RHB Posted July 4, 2005 Author Share Posted July 4, 2005 <{POST_SNAPBACK}> Sorry for the duplicate. I hit reply by mistake twice. Hope I don't do that again! But that was my first post and I got confused. Link to comment Share on other sites More sharing options...
gunner Posted July 4, 2005 Share Posted July 4, 2005 Don't worry about it. Progress, not perfection! If it isn't broke, tweak it. Link to comment Share on other sites More sharing options...
