Moderators rridgely Posted May 6, 2005 Moderators Share Posted May 6, 2005 Link to comment Share on other sites More sharing options...
Tarun Posted May 6, 2005 Share Posted May 6, 2005 You upload your files via FTP to the server. The server IP will be on the left usually. At least, that's what I have to do for my site. Link to comment Share on other sites More sharing options...
Moderators rridgely Posted May 6, 2005 Author Moderators Share Posted May 6, 2005 Ok, I'm thinking about just buying front page. You can get front page 98 for about 20 dollars on ebay. But befoe I do Is their any good freeware alternatives. Link to comment Share on other sites More sharing options...
Tarun Posted May 6, 2005 Share Posted May 6, 2005 Ok, I'm thinking about just buying front page. You can get front page 98 for about 20 dollars on ebay. But befoe I do Is their any good freeware alternatives. <{POST_SNAPBACK}> Look into phpBB, CPGNuke, PHP-Nuke (though not very secure). Link to comment Share on other sites More sharing options...
xd3vilx Posted May 7, 2005 Share Posted May 7, 2005 Use SMF(Same As Phpbb) With TinyPortal...They Are Both Easy To Install... Fantastico Is A Auto-Installer That Help U Install Script Like Phpbb,Smf,Mambo,Php-Nuke And Etc PS:ftp server for your web host is ftp.ugtech.net I am also using ugtech... Link to comment Share on other sites More sharing options...
Moderators rridgely Posted May 7, 2005 Author Moderators Share Posted May 7, 2005 Use SMF(Same As Phpbb) With TinyPortal...They Are Both Easy To Install...Fantastico Is A Auto-Installer That Help U Install Script Like Phpbb,Smf,Mambo,Php-Nuke And Etc PS:ftp server for your web host is ftp.ugtech.net I am also using ugtech... <{POST_SNAPBACK}> Thank you so much! I have two questions and then I think I will finally have this understood. 1. FTP- I havent tried loding anything to my site yet but how do I do it/what do I need to do it. 2. I posted a link on the Ugtech forum (my user name is ryan223) and thanks for the help, but I still cant find the Index page ( I found something in public_ html called index. html and cleared it but my webpage didnt change.) Link to comment Share on other sites More sharing options...
Moderators rridgely Posted May 7, 2005 Author Moderators Share Posted May 7, 2005 Ok I have Finally figured this website thing out (I still need to learn HTML). I have set up a subdomain for a callendar but I need an easy way to put it on the site. Also I still cant figure out how to edit my index/home page. Link to comment Share on other sites More sharing options...
Tarun Posted May 7, 2005 Share Posted May 7, 2005 Ok I have Finally figured this website thing out (I still need to learn HTML). I have set up a subdomain for a callendar but I need an easy way to put it on the site. Also I still cant figure out how to edit my index/home page. <{POST_SNAPBACK}> Usually it's the index.html page. Edit that and upload. Link to comment Share on other sites More sharing options...
Moderators rridgely Posted May 7, 2005 Author Moderators Share Posted May 7, 2005 Link to comment Share on other sites More sharing options...
DjLizard Posted May 7, 2005 Share Posted May 7, 2005 I'm surprised nobody jumped to tell how horrible Frontpage is. rridgely: don't buy FrontPage, or anything, for that matter. Learn to edit HTML and PHP by hand. Click here if CCleaner Issues are re-appearing DjLizard.net DjLizard.net wiki Dial-a-fix Dial-a-fix tips DjLizard.net software support forum Do you live in Bradenton, Sarasota, Tampa, or St. Petersburg, Florida? Visit Digital Doctors where I work Link to comment Share on other sites More sharing options...
agumon Posted May 7, 2005 Share Posted May 7, 2005 I'm surprised nobody jumped to tell how horrible Frontpage is. rridgely: don't buy FrontPage, or anything, for that matter. Learn to edit HTML and PHP by hand. frontpage is easy to use... but much less powerful than the macromedia dreamweaver... i used notepad for html coding in the past... but it is not easy to make changes... and now using dreamweaver (school want us to learn)... if i want to html... --==aGumon==-- Link to comment Share on other sites More sharing options...
xd3vilx Posted May 7, 2005 Share Posted May 7, 2005 I'm surprised nobody jumped to tell how horrible Frontpage is. rridgely: don't buy FrontPage, or anything, for that matter. Learn to edit HTML and PHP by hand. <{POST_SNAPBACK}> Frontpage Is Not Horrible... Link to comment Share on other sites More sharing options...
DjLizard Posted May 7, 2005 Share Posted May 7, 2005 Yes it is. Once you learn HTML for yourself, and read the code that FrontPage has generated, you'll agree. Microsoft Word is even worse. Note that this is not an opinion, but actually a fact. Click here if CCleaner Issues are re-appearing DjLizard.net DjLizard.net wiki Dial-a-fix Dial-a-fix tips DjLizard.net software support forum Do you live in Bradenton, Sarasota, Tampa, or St. Petersburg, Florida? Visit Digital Doctors where I work Link to comment Share on other sites More sharing options...
agumon Posted May 7, 2005 Share Posted May 7, 2005 Microsoft Word is even worse. why? --==aGumon==-- Link to comment Share on other sites More sharing options...
agumon Posted May 7, 2005 Share Posted May 7, 2005 it is better if you know the coding of html first then use program like frontpage... --==aGumon==-- Link to comment Share on other sites More sharing options...
DjLizard Posted May 7, 2005 Share Posted May 7, 2005 Microsoft Word generates the most incompatible HTML in the universe. FrontPage takes second place. http://www.fourmilab.ch/webtools/demoroniser/ - here is a program created specifically for repairing kludgy, moronic Microsoft-generated HTML. (hopefully, by reading that page, you can start to see the point of my rantings...) EDIT>>(that is only the *beginning* of "junk HTML" -- FrontPage is actually much worse) EDIT2>>(the author of demoroniser is the founder of Autodesk and co-author of AutoCAD!) Click here if CCleaner Issues are re-appearing DjLizard.net DjLizard.net wiki Dial-a-fix Dial-a-fix tips DjLizard.net software support forum Do you live in Bradenton, Sarasota, Tampa, or St. Petersburg, Florida? Visit Digital Doctors where I work Link to comment Share on other sites More sharing options...
agumon Posted May 7, 2005 Share Posted May 7, 2005 Microsoft Word generates the most incompatible HTML in the universe. FrontPage takes second place. http://www.fourmilab.ch/webtools/demoroniser/ - here is a program created specifically for repairing kludgy, moronic Microsoft-generated HTML. (hopefully, by reading that page, you can start to see the point of my rantings...) EDIT>>(that is only the *beginning* of "junk HTML" -- FrontPage is actually much worse) EDIT2>>(the author of demoroniser is the founder of Autodesk and co-author of AutoCAD!) i see... didnt know that microsft word generate so much html code... --==aGumon==-- Link to comment Share on other sites More sharing options...
