blarty-fargo Posted May 20, 2012 Share Posted May 20, 2012 Hi all In the "Indexing Options" widget from the control panel, I untick "Internet Explorer History" because I use Firefox. However, I noticed that if I run CCleaner the "Internet Explorer History" entry is re-ticked!! Anyone know which option in CCleaner I can uncheck to override this behaviour? (I have "Applications | Windows | MS Search" unticked) BF Link to comment Share on other sites More sharing options...
blarty-fargo Posted May 20, 2012 Author Share Posted May 20, 2012 Ah - found it! If you have "Internet Explorer | History" selected in CCleaner, it will make the Indexer forget that you don't want to index IE history. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted May 20, 2012 Moderators Share Posted May 20, 2012 Perhaps you could have added this info to this thread here, but I'll link to it for user reference and vice versa. http://forum.piriform.com/index.php?showtopic=35872 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 20, 2012 Moderators Share Posted May 20, 2012 strange I clean ie history and don't lose my preference to not index history, maybe the is a setting in internet explorer I've used to make it so. also just because you don't use ie doesn't mean windows doesn't. it's especially good for your junk cleaning purposes to clean that section as you've no need at all for the junk left behind. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
