amiek Posted January 8, 2012 Share Posted January 8, 2012 First of all, I've been using CCleaner for many years now and never had a complaint about the program. Unfortunately now I do. Somewhere in the end of Sempteber there was an update of CCleaner and then the problem began. My log files were filled with critical errors about Windows Search. Every day the database was corrupt. I tried everything I knew, rebuilding the database, new indexing, removing IE from the list of indexing, but nothing worked. Every day my logfiles filled after startup with this: (the first log entry source is from ESENT, all subsequent ones from Search) ----------------------------------------------------------- Windows (3236) Windows: Error -1811 occurred while opening logfile C:\ProgramData\Microsoft\Search\Data\Applications\Windows\MSS001DF.log. ----------------------------------------------------------- The Windows Search Service cannot open the Jet property store. Details: 0x%08x (0xc0041800 - The content index database is corrupt. (HRESULT : 0xc0041800)) ----------------------------------------------------------- The search service has detected corrupted data files in the index {id=4700}. The service will attempt to automatically correct this problem by rebuilding the index. Details: The content index catalog is corrupt. (HRESULT : 0xc0041801) (0xc0041801) ------------------------------------------------------------ The Windows Search Service is being stopped because there is a problem with the indexer: The catalog is corrupt. Details: The content index catalog is corrupt. (HRESULT : 0xc0041801) (0xc0041801) ------------------------------------------------------------ The Windows Search Service cannot load the property store information. Context: Windows Application, SystemIndex Catalog Details: The content index database is corrupt. (HRESULT : 0xc0041800) (0xc0041800) ------------------------------------------------------------- The plug-in in <Search.JetPropStore> cannot be initialized. Context: Windows Application, SystemIndex Catalog Details: The content index catalog is corrupt. (HRESULT : 0xc0041801) (0xc0041801) -------------------------------------------------------------- The plug-in in <Search.TripoliIndexer> cannot be initialized. Context: Windows Application, SystemIndex Catalog Details: Element not found. (HRESULT : 0x80070490) (0x80070490) --------------------------------------------------------------- The gatherer object cannot be initialized. Context: Windows Application, SystemIndex Catalog Details: The content index catalog is corrupt. (HRESULT : 0xc0041801) (0xc0041801) ---------------------------------------------------------------- The application cannot be initialized. Context: Windows Application Details: The content index catalog is corrupt. (HRESULT : 0xc0041801) (0xc0041801) ---------------------------------------------------------------- The index cannot be initialized. Details: The content index catalog is corrupt. (HRESULT : 0xc0041801) (0xc0041801) ----------------------------------------------------------------- I have Windows 7 Home premium, 64-bit. Then it occured to me, that it only happed after using the cleanup from CCleaner, which I ususally do before shutting down my computer. And after I looked into CCleaner/Applications/Windows I found MS Search. After I ticked it of, the errors in my log files disappeared. No more database corruption. Could someone please look into this? Thanks so much. Link to comment Share on other sites More sharing options...
TheWebAtom Posted January 8, 2012 Share Posted January 8, 2012 Is search continuing to function after being cleaned with CCleaner? If it isn't; then it could be a problem with the Windows service(s) responsible for monitoring the filesystem. Go to Start --> Run. Type "cmd.exe" to open the command prompt. Type "sfc.exe /scannow" into the command prompt and press Enter. Then attempt to rebuild the database; purge it with CCleaner, reboot etc to see if the issues persist. I'm Shane. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 8, 2012 Share Posted January 8, 2012 This is caused by MS Search in Applications - Windows winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
amiek Posted January 8, 2012 Author Share Posted January 8, 2012 Is search continuing to function after being cleaned with CCleaner? If it isn't; then it could be a problem with the Windows service(s) responsible for monitoring the filesystem. Go to Start --> Run. Type "cmd.exe" to open the command prompt. Type "sfc.exe /scannow" into the command prompt and press Enter. Then attempt to rebuild the database; purge it with CCleaner, reboot etc to see if the issues persist. Search is still working and sfc /scannow does not solve everyting, in this case is does nothing. This is caused by MS Search in Applications - Windows I know that, I wrote that. The only thing is that I reported it, so someone can do something about it to fix it. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 9, 2012 Share Posted January 9, 2012 It has gone unchecked for a while, I think this actually may be the intended effect. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
amiek Posted January 9, 2012 Author Share Posted January 9, 2012 It seems better to me (but who am I) that they leave it unchecked and let the user decide if he/she wants to check it or not. Now, when I install it on other computers I have to remember to uncheck it everytime. Link to comment Share on other sites More sharing options...
Guest MrT Posted January 25, 2012 Share Posted January 25, 2012 Please, upgrade to CCleaner v3.15 Improved cleaning for Windows Log Files and MS Search. Thanks Link to comment Share on other sites More sharing options...
gringopig Posted January 25, 2012 Share Posted January 25, 2012 The application will no longer delete the .jrs and .edb database files I believe... This has to be commended as the Search database should not bbe corrupted now. Have you tested this MrT? :-) Link to comment Share on other sites More sharing options...
Super Fast Posted January 25, 2012 Share Posted January 25, 2012 This is interesting. I don't really use MS Search, however, as Locate32 is instant. Locate32 builds a 1 time index of all your files, so any future searches are instant. Instead of searching your entire drive each time & wasting time. Locate32 does find as you type as well. Link to comment Share on other sites More sharing options...
