Speccy 1.14.288 delivers error msgs in multiple fields
RMcVaugh
Hi eveyone!
I just downloaded Speccy to see if it could help me ID the memory in my system and after running it identified my OS and optical drive but on all other fields it returned the following error:
"Cannot initialise SPC dll"
I am running a Dell Dimension 3000, XP SP3
Can someone help me?
Thanks a bunch!
Bob
Link to comment
  • Moderators
This question may seem odd, however everyone who has claimed your issue has fixed it via this.
Have you rebooted your computer, if not do so
Also are you running any sort of sandboxing program (like sandboxie)
Link to comment
  • Moderators
Can you run Services.msc and tell us if the service "windows management instrumentation" is started and automatic?
I guess threatfire might be stopping something, but on cursory look I didn't find anything about it blocking WMI reads.
Some People had the same issues as you from Outpost Firewall until they turned off "Anti-Leak" does Threatfire have something similar? What Firewall are you running (I'm not familure with ThreatFire is it a firewall as well as an antivirus?)
Are you running speccy as an administrator account?
Have you changed any settings in your computer's bios?
http://forum.piriform.com/index.php?showtopic=32840&view=findpost&p=199522
Link to comment
Hi folks!
I ran through all the questions and fixes from Nergal and hazelnut and still get the same results Here is what I did:
I ran Services.msc and "windows management instrumentation" is started and on automatic.
As far as I can tell, Threatfire is just an antivirus and not a firewall and does not have a setting similar to "Anti-Leak".
I am running Speccy as an administrator.
I have not changed any of my BIOS settings.
I tried disabling Teatimer, rebooted and still got the error message.
I also tried disabling ThreatFire and running Speccy and got the same error message (though I did not reboot as ThreatFire has a disable option within the program).
Any other ideas? I apologize for being the problem child and I greatly appreciate all the help given.
Link to comment
  • Moderators
Register a new account
Sign in
Important Information
