1200 Posted January 27, 2007 Share Posted January 27, 2007 hello everyone, for some weird reason my xp pro started to acting strange. when it times for stand by it just stay there,i don't think it is freezing because i pressed the number lock key and it still work. (it did change to the stand by screen though, just stay there .any help would be appreciated? Nlite Tutorial, Wireless Security Tutorial Link to comment Share on other sites More sharing options...
Humpty Posted January 27, 2007 Share Posted January 27, 2007 Any help at the link bekow? Kelly's stanby issues Link to comment Share on other sites More sharing options...
1200 Posted January 28, 2007 Author Share Posted January 28, 2007 first,set my stand by less then 45 minutes so i don't know if it would works with the instructions. secondly, the links to download the hotfix does not works,but thnks Nlite Tutorial, Wireless Security Tutorial Link to comment Share on other sites More sharing options...
burtman Posted February 3, 2007 Share Posted February 3, 2007 .... i don't think it is freezing because i pressed the number lock key and it still work. The Num Lock / Caps Lock keys are low-level operations and never (appear) to be affected by windows-crashes / locks etc. They will 'almost' always work (for some reason - I have no clue why; maybe Dos related ...another topic) If they do appear to work there is a slight possiblity that windows will come back to life (usually highly unlikely) - if, however, said buttons refuse to work at all ....then u may as well power-off (ideally you will have XP and above !) Link to comment Share on other sites More sharing options...
