klumy 0 Posted October 29, 2006 Share Posted October 29, 2006 each Time I select not to delete IE Cookies, I see that the cookies will also be deleted. Because I can't login to some forums anymore. I must renter my forum password. so I think this is a bug Link to post Share on other sites
Moderators hazelnut 5 Posted October 29, 2006 Moderators Share Posted October 29, 2006 CCleaner is not fully compatable with IE 7 yet. To avoid cookies being deleted don't run ccleaner at startup and untick "delete index.dat" in ccleaner windows. Link to post Share on other sites
klumy 0 Posted October 29, 2006 Author Share Posted October 29, 2006 what is the index.dat for? Link to post Share on other sites
YoKenny 0 Posted November 1, 2006 Share Posted November 1, 2006 Index.dat From Wikipedia, the free encyclopedia: http://en.wikipedia.org/wiki/Index.dat Link to post Share on other sites
heugh 0 Posted November 6, 2006 Share Posted November 6, 2006 CCleaner is not fully compatable with IE 7 yet. To avoid cookies being deleted don't run ccleaner at startup and untick "delete index.dat" in ccleaner windows. Does anyone have any idea when CCleaner will be compatible with IE7? I have tried unchecking "delete index.dat" and my safe cookies are still disappearing! I am having to log in each time I use my so-called safe sites. On the bright side I suppose we have to praise IE7 for the extra security it provides. Link to post Share on other sites
Moderators hazelnut 5 Posted November 6, 2006 Moderators Share Posted November 6, 2006 Heugh, do you have ccleaner set to run at startup? Also welcome to the forum Link to post Share on other sites
heugh 0 Posted November 9, 2006 Share Posted November 9, 2006 Heugh, do you have ccleaner set to run at startup? Also welcome to the forum Hazelnut - my apologies for not getting back right away. No, I don't have CCleaner running at start up. Thank you for the welcome. Link to post Share on other sites
Moderators hazelnut 5 Posted November 9, 2006 Moderators Share Posted November 9, 2006 A rather obvious question heugh but I will ask it anyway! Have you used the options in the ccleaner program to click on the cookie button and move the cookies you want to save over to the other side of the page? Link to post Share on other sites
heugh 0 Posted November 9, 2006 Share Posted November 9, 2006 Hazelnut - yes I have saved the cookies I want to keep under options>cookies>cookies to keep. Maybe I should uncheck Delete index.dat files and re-boot? I didn?t re-boot when I did this first time round - just a thought? Link to post Share on other sites
Moderators hazelnut 5 Posted November 9, 2006 Moderators Share Posted November 9, 2006 It's worth a try, I use IE7, don't have ccleaner set to run at startup and have "delete index.dat" unchecked and all my cookies I want are saved. So yes it's worth a try Link to post Share on other sites
heugh 0 Posted November 9, 2006 Share Posted November 9, 2006 No, that didn't work either. I had to sign into my IE homepage, plus my usual and regular sites. No doubt it will be something really small and obvious - but I am blind to it. This also happened when I was running IE7 Beta and decided, because of its problems, uninstalled and went back to IE6. The minor annoyances, that I personally had with IE7 Beta, seem to have been ironed out - but it is little things like my cookies being eaten by the cookie monster really gets to me. Maybe I should get my ten-year-old nephew to look at my pc when I get back to the UK - he will sort it!! Link to post Share on other sites
Moderators hazelnut 5 Posted November 10, 2006 Moderators Share Posted November 10, 2006 Let us know when you sort it, it may help someone else. As you say it will probably be something small, as most of us here have solved it through the method above. Send your nephew round to my house if he's that good!! Link to post Share on other sites
CobraWing 0 Posted November 12, 2006 Share Posted November 12, 2006 I'm new to the forum but not to the Cleaner program. I just wanted to chime in and state that the same thing is happening to me and to someone else that I know. No matter how we configure the buttons, IE7 continues to delete the cookies. I've noticed that IE7 is handling deletion of trace files quite a bit differently than IE6. Hopefully the developers here will resolve this issue shortly. I was about to post this issue but I'm glad it has already been reported. Otherwise, this is a great program and I can't wait to use it again with IE7. Link to post Share on other sites
Tarq57 0 Posted November 12, 2006 Share Posted November 12, 2006 I am in exactly the same position as CobraWing. A search, and many posts on other forums pointed me in this direction. Although I prefer to think of it as a bug in IE7 rather than in CCleaner. No prizes for guessing who's going to end up releasing a new compatable version first, though! This discussion is also occurring on the Microsoft forums, so maybe it's not just a cc issue. Link to post Share on other sites
heugh 0 Posted November 13, 2006 Share Posted November 13, 2006 Now I am totally confused! I have XP Pro on my pc - and my wife runs XP Home on her laptop and her cookies are NEVER erased when she runs CCleaner with the same settings I have. I just thought I would share this information. Link to post Share on other sites
CobraWing 0 Posted November 13, 2006 Share Posted November 13, 2006 Are either one of you running IE7? I've been running XP Home with CClean with no problem until I downloaded IE7. Link to post Share on other sites
Tarq57 0 Posted November 14, 2006 Share Posted November 14, 2006 And after unticking "delete index dat" try restarting. Worked for me. Link to post Share on other sites
heugh 0 Posted November 14, 2006 Share Posted November 14, 2006 We are both running IE7. I did re-boot after unticking "Delete Index.dat files" and it is just the same. This has to be something really silly. We will make it! Link to post Share on other sites
Tarq57 0 Posted November 14, 2006 Share Posted November 14, 2006 Have you tried altering the IE7 privacy settings and/or ticking the checkbox "overide automatic cookie handling"? I went through a bit of a troubleshoot on this one, and it's come right now. (See the other thread-staying logged on) But would like to be able to delete whatever i want to without having to go through it all again. You could try deleting all the cookies, incl whitelisted, and re-installing one by one. That's what I did. Can't comment on whether or not that was what did the trick. Not of itself, anyway. Link to post Share on other sites
heugh 0 Posted November 25, 2006 Share Posted November 25, 2006 The new version of CCleaner v1.35.424 (launched today) has addressed a few issues such as "Fixed some IE7 cookie handling issues" and "Fixed IE7 Autocomplete form data cleaning" so we will see how it goes. Tarq57 I didn't change anything in the IE7 privacy settings as I am sure this cookie issue will be fixed by Microsoft or perhaps our good ol' CCleaner will sort it for us. Link to post Share on other sites
Tarq57 0 Posted November 26, 2006 Share Posted November 26, 2006 Heugh, yes, absolutely! I'm sure Microsoft will come through! And if they don't, maybe all the other after-market software makers will pick up the pieces. Again. Link to post Share on other sites
