mycky Posted September 29, 2006 Share Posted September 29, 2006 help pls if you can i updated ccleaner to ver 1.33 and all was well for ages but now when i click on " check for updates now " nothing happens and my current browser will not load. I have IE and FF but whichever i make my default i get the same response. Can anyone help i dont believe it is anything to do with ccleaner Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted September 29, 2006 Moderators Share Posted September 29, 2006 Hello mycky. As you already have the latest version, just wondered why you are trying to update. Is the update link at the bottom of the ccleaner screen in blue? Do you have xp? Are you having any other problems with the internet apart from this? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
mycky Posted September 30, 2006 Author Share Posted September 30, 2006 not trying to update anything but after running ccleaner it was the quickest way to access ccleaner home page. yes it is in blue at the bottom of the page yes windows xp home with sp 2 Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted September 30, 2006 Moderators Share Posted September 30, 2006 By home page, do you mean the forums ? This is where the update link takes you, can you get there by using this link? http://www.ccleaner.com/update/?v=1.33.382&l=1033 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
