tomg8 Posted May 20 Share Posted May 20 I see resetting to default is the easiest way to go to get Custom Clean to get back to asking to close Edge. Is there a way to save the cookies that have been saved? Link to comment Share on other sites More sharing options...
Moderators nukecad Posted May 21 Moderators Share Posted May 21 Yes there is. In CCleaner go to Options>Cookies and right-click anywhere on the 'Cookies to Keep' list, the list on the right. You will get a context menu with an option to 'Export' - which writes the full list as a text file (cookies.txt) that you save. When you are ready to put them back then it's the same, right-click in the (empty) list and 'Import' the textfile. The same 'Cookies to Keep' list is used by both Health Check and Custom Clean. PS. It's often worth right-clicking things in any app, mostly nothing happens but you'll sometimes/often get a context menu with extra options like that. *** Out of Beer Error ->->-> Recovering Memory *** Keep getting logged out of websites? See this link: https://community.ccleaner.com/topic/67601-saved-passwords/#comment-349999 Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link: https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
tomg8 Posted May 21 Author Share Posted May 21 Thanks nukecad, that worked great! Link to comment Share on other sites More sharing options...
