bboma Posted March 26 Share Posted March 26 I have used ccleaner for 20? years. This just started within the last 2 weeks. Can someone explain? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 26 Moderators Share Posted March 26 Lately edge gets stuck on exit, if you check under background processes on task manager you'll probably find it there under Microsoft edge kill the browser sub process and CCleaner should be able to clean ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
bboma Posted April 3 Author Share Posted April 3 CCleaner used to close Edge. Link to comment Share on other sites More sharing options...
