cdk Posted April 20, 2023 Share Posted April 20, 2023 Hi I have a number of Pinned tabs in my Microsoft Edge - Version 112.0.1722 (64bit) But Ccleaner seems to clear them out completely when cleaning. Am I doing something wrong? Would appreciate some help Regards Link to comment Share on other sites More sharing options...
Moderators nukecad Posted April 21, 2023 Moderators Share Posted April 21, 2023 Are you using Custom Clean, and do you have 'Session' ticked for Edge Chromium? If so then unticking it will leave your previous session (open tabs, active logins, etc.) alone and won't clear them, so they should still be there next time you open Edge. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
cdk Posted April 24, 2023 Author Share Posted April 24, 2023 Hi Thanks for your answer. I have cleared the "Session" box in both Microsoft Edge and Edge Chromium in the Custom Clean settings. Hope that solves the problem Regards Link to comment Share on other sites More sharing options...
