Larry42 Posted March 28, 2023 Share Posted March 28, 2023 I clicked the do not show again box on closing and cleaning Edge Chromium. How do I undo? Link to comment Share on other sites More sharing options...
Moderators nukecad Posted March 28, 2023 Moderators Share Posted March 28, 2023 It Skips Edge because Edge is still open in the background. See this for how to turn off Edge background running so that CCleaner can clean it rather than skipping it: As for the 'Do you want to close EDGE' message. If you stop Edge from background running then you don't need it because CCleaner won't need to ask you to close Edge anyway. If you don't stop Edge from background running and so do want that message back then the easiest way is to reset CCleaner to the default settings, or if that doesn't work to uninstall/reinstall CCleaner. That does of course mean you'll then have to set up any other changes that you had made again. *** Out of Beer Error ->->-> Recovering Memory *** Worried about 'Tracking Files'? Worried about why some files come back after cleaning? See this link:https://community.ccleaner.com/topic/52668-tracking-files/?tab=comments#comment-300043 Link to comment Share on other sites More sharing options...
Larry42 Posted March 28, 2023 Author Share Posted March 28, 2023 Thanks @nukecad. I turned off "Continue running...." and that fixed my problem (I had previously turned off start up Boost). Appreciate your prompt, accurate response. Link to comment Share on other sites More sharing options...
