Silver66 Posted August 20, 2006 Share Posted August 20, 2006 When I run the cleaner, after analyze, the CPU load goes to 100%. It stays there after shutting down CCleaner. Only way to fix is to shutdown and restart ZoneAlarm. Anyone have a similar experience? Any fixes? Link to comment Share on other sites More sharing options...
andreasm Posted August 22, 2006 Share Posted August 22, 2006 which process does use 100% of cpu? Zonealarm? my private homepage www.energie-bewusstsein.de - stop wasting energy! Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 22, 2006 Moderators Share Posted August 22, 2006 "Maybe" untick the option to clean ZoneAlarm in the large Cleaner button area since according to some posts the newer versions of ZA protects its logs against programs such as CCleaner. Note: If you've installed winapp2.ini there will also be a ZoneAlarm cleaner named "Internet Logs" Link to comment Share on other sites More sharing options...
Silver66 Posted August 26, 2006 Author Share Posted August 26, 2006 "Maybe" untick the option to clean ZoneAlarm in the large Cleaner button area since according to some posts the newer versions of ZA protects its logs against programs such as CCleaner. Note: If you've installed winapp2.ini there will also be a ZoneAlarm cleaner named "Internet Logs" I tried this and it did not work. Same results. 100% cpu load after running cleaner and closing... Link to comment Share on other sites More sharing options...
