jt799 Posted February 8, 2022 Share Posted February 8, 2022 (edited) Hello, after upgrading CCleaner to the latest version, I started using the new CCleaner functions. I trier to uninstall or downgrade to factory settings the "Google" application as proposed by CCleaner. My Phone has since frozen, stuck on a black screen while the blue LED is continuously on. I have tried several times to reboot, pressing the start and low volume buttons together for 5 seconds, to no avail. I do get the start up screen for a few seconds but it ends up with the black screen. Help, please ! Edited February 8, 2022 by jt799 Link to comment Share on other sites More sharing options...
Admin Azra CCleaner Posted February 9, 2022 Admin Share Posted February 9, 2022 Hi @jt799 Our team would like to investigate this furtherly, can you please contact our support at support@ccleaner.com. Furthermore, to “revive” the device can you please try to drain the device to 0% (so no charging) after recharge? And can you advise what APP you were trying to factory reset? Was it an app by the name “Google” or some other app with “Google” in the name? Link to comment Share on other sites More sharing options...
