helix Posted July 17, 2006 Share Posted July 17, 2006 WinXP SP2 When I run CCleaner 1.31.325 it repeatedly reports three issues that it is unable to fix: (i) 'The COM component CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A} references an invalid CLSID. These are often left behind after uninstalling software. Solution: Delete the registry value.' (ii) 'The COM component CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} references an invalid CLSID. These are often left behind after uninstalling software. Solution: Delete the registry value.' (iii) 'The COM component CLSID\{D27CDB70-AE6D-11cf-96B8-444553540000} references an invalid CLSID. These are often left behind after uninstalling software. Solution: Delete the registry value.' When I open and attempt to delete them in RegEdit I receive the message: 'Unable to delete all specified values' or 'Cannot delete. Error while deleting'. Any ideas? (in non-techy language ideally!) Thanks in advance. Helix Link to comment Share on other sites More sharing options...
TheFiresInTheSky Posted July 17, 2006 Share Posted July 17, 2006 try it in safe mode. it could be a program thats running or something. its dangerous to manually delete them so i dont advise you do that. try CCleaner in safe mode first and see if that works. to boot into safe mode, press F8 repeatedly while booting up. Link to comment Share on other sites More sharing options...
helix Posted July 18, 2006 Author Share Posted July 18, 2006 I ran CCleaner in safe mode but got exactly the same result. Thanks for the suggestion anyway. Do you think I should now move this to the Bug forum? Helix PS If it's any help the Data column of CCleaner's issue scan results also gives the following information for all three unfixable issues: InProcServer32\C:\WINDOWS\system32\Macromed\Flash\Flash8b.ocx Link to comment Share on other sites More sharing options...
Moderators Andavari Posted July 18, 2006 Moderators Share Posted July 18, 2006 What to do if removed Issues in CCleaner keep reappearing: URL: http://wiki.djlizard.net/Dial-a-fix_tips#CCleaner Link to comment Share on other sites More sharing options...
helix Posted July 18, 2006 Author Share Posted July 18, 2006 That did the trick! Many thanks. Link to comment Share on other sites More sharing options...
