debbynorm Posted February 23, 2015 Share Posted February 23, 2015 No matter how hard I try or even deleting CCLEANER and re-downloading it, the Recycle Bin will not empty and keeps on growing. It started out with 8 files (all jpg's) now it's up to 30. The Recycle Bin elsewhere in the computer says it's empty just not in CCLEANER. Norm Link to comment Share on other sites More sharing options...
dvdbane Posted February 23, 2015 Share Posted February 23, 2015 view this topic http://forum.piriform.com/index.php?showtopic=42673 Link to comment Share on other sites More sharing options...
debbynorm Posted February 27, 2015 Author Share Posted February 27, 2015 view this topic http://forum.piriform.com/index.php?showtopic=42673 I'm using Windows 8.1 and could not get my computer to recognize the command prompt rd /s /q C:\Recycle.bin. (Option One) In option two, the procedure is for VISTA and it says it will re-create a Recycle Bin file automatically. Will it do the same for 8.1 and is the entire procedure for VISTA the same as for 8.1? Norm Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted February 27, 2015 Moderators Share Posted February 27, 2015 When you say it won't recognise it, what error message does it say? Did you use an elevated cmd prompt? Did you refresh the desktop afterwards? Just copy and paste this... RD /S /Q C:\$Recycle.bin Both option one and option two should definitely work on Windows 8.1 (I have used it personally) Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
