Newt Posted October 10, 2014 Share Posted October 10, 2014 Speccy gives some cool hard drive stats like "Power on Count" and "Power on Time". Just a couple of questions I have: 1) What keeps track of these figures? Are these figures stored in the hard drive itself (i.e. in a chip), or does Windows monitor them and it is Windows that holds these figures? 2) If the primary hard drive is formatted and Windows is reinstalled, will stats like "Power on Count" and "Power on Time" be reset? Link to comment Share on other sites More sharing options...
Moderators mta Posted October 11, 2014 Moderators Share Posted October 11, 2014 1) stored by S.M.A.R.T in the hard drive firmware. 2) cannot be reset. otherwise people would wind back those figures and sell the drive as new. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
Newt Posted October 11, 2014 Author Share Posted October 11, 2014 Thanks for clarifying. Link to comment Share on other sites More sharing options...
faariwasi Posted November 4, 2014 Share Posted November 4, 2014 I think this is a legitimate bug. Running GPU-Z shows my crossfire as active, yet Speccy shows it as disabled. Single card crossfire apparently doesn't have the option to disable crossfire in Catalyst Control Center, at least I don't. Running GPU performance tests shows usage on both GPUs and sensors show increase in heat rougly equal on both GPUs. It's clear to me that both cards are sharing the load, hence crossfire is working. Speccy needs to accurately display crossfire settings or not display them at all. This includes people using crossfire as well as crossfire x2. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 4, 2014 Moderators Share Posted November 4, 2014 Faariwasi, this is a thread on hard drives, please start your own ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
