jbomb77 Posted January 25, 2006 Share Posted January 25, 2006 I'll primarily be burning my music and photos. I need to burn my music into Data CD though so I can keep my ID3 tags. Thoughts on which one is the best? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted January 25, 2006 Moderators Share Posted January 25, 2006 Audio CD burning only Burrrn: Can create audio CD's from already compressed audio files like .mp3, .ogg, and some formats you may have never heard about, even uncompressed .wav. I highly recommend Burrrn. You won't find any easier way to quickly burrrn an audio CD, and you won't have to go through any options/settings to do so since it's all on the easy-to-use main GUI window. Whatsmore Burrrn automatically creates gapless audio CD's without 2 second gaps which is extremely useful because you'll never forget to enable such an option. Note: Burrrn only creates audio CD's! _________________________ Data CD burning/and audio CD burning Burnatonce: Can do data, however you'll need to download ProDVD do burn DVD's with it. It can also do audio CD's like Burrrn however there's more steps in the creation of an audio CD using Burnatonce, and you have to manually enable the option to create gapless audio CD's without 2 second gaps. DeepBurner Free: The audio CD's it creates won't be gapless even if enabling the option for your burner drive, I tested it's ability to create a gapless CD and it doesn't work it will instead place 1.70 second gaps inbetween the tracks instead of the standard 2 second gaps. With that being said it could have been something to do with my system and the writer drive I used. It's ability to create data CD's is however very good, and it's what I use on my old Win98 system to create backup CD-RW's with. CDBurnerXP Pro: I found it to be a bit bloated when compared to Burnatonce and DeepBurner, however so as to not sound bias I'll let someone who actually uses it commit on it. Link to comment Share on other sites More sharing options...
Krak Posted January 25, 2006 Share Posted January 25, 2006 Cd Burner pro! He has all except direct copying from cd to cd ... I used this tool for a long time and i was thrilled but the installation was too big so now i use CDR Tools (Front End for Windows)! Link to comment Share on other sites More sharing options...
Moderators rridgely Posted January 25, 2006 Moderators Share Posted January 25, 2006 I use burnatonce. Just get the pro dvd plug in and it can do everything that any other program can.(deepburner coastered a few discs and cd burner xp pro crashed a few times while burning) Link to comment Share on other sites More sharing options...
jbomb77 Posted January 25, 2006 Author Share Posted January 25, 2006 I use burnatonce. Just get the pro dvd plug in and it can do everything that any other program can.(deepburner coastered a few discs and cd burner xp pro crashed a few times while burning) I'm gonna try it out now...thanks. Link to comment Share on other sites More sharing options...
