CCleaner Community Forums
Primithras
Wrong temperature i5 2500K
I have an i5 2500K with a Gigabyte Z68X-UD3H-B3 motherboard and the CPU temperature is off by 9-10-11°.
Screenshot (TouchBIOS is a Gigabyte tool)
Share this post
Link to post
The CPU temp (shown by the Gigabyte utility) can't be lower than the system temperature unless you have a liquid chilled or Peltier CPU cooler attached to the CPU. A CPU with a really good heatsink and cooling fan should (as seen by Speccy) run only 5 to 10 C warmer than the overall system temp inside the computer case. I think that Speccy is reporting the correct CPU temp and that the Gigabyte utility is not.
Share this post
Link to post
I saw the title and thought "Smoking Hot"
2500 degrees Kelvin
Share this post
Link to post
loooool @ Alan_B
Hi there!
I'm wondering myself. I use an i7 2600K @ (actually) 4Ghz on a MSI P67A-GD53 (B3) mainboard.
However, my MSI Control Center says:
CPU = 36° C
System = 33° C
Speccy:
CPU = 43° C
System = 43° C
I'm pretty sure, my BIOS itself is detecting a lower value because my CPU fan is running at 50% efficiency, with a target temperature of 40° C.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
