Moderators Augeas Posted October 19, 2011 Moderators Share Posted October 19, 2011 It appears that in v1.141 the ability to filter the scan results in the File or Path box (in Advanced Mode) has been lost. The box seems to accept filenames in the form of *name, but that's no good if you want to search the filename beginning from the left, which is a perfectly natural thing to do. Reverting to 140 reinstates the filter facility. I'll try again tomorrow. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 19, 2011 Moderators Share Posted October 19, 2011 looks like it works Left to right as well once you put a * at the end or finish the full name of the file. I thing this was to counter the recent complaint that the "just type" was being too slow as you would type p and have to wait till it had loaded the P results before you could type S Shorter explaination typing Pstart gave me no results typing Pstart.bak gave me the results I looked for *P began to shrink the possible results typing Pstart* gave me the results I looked for ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Moderators Augeas Posted October 20, 2011 Author Moderators Share Posted October 20, 2011 You're right, Nergal, the box does work if an * if appended to the filename, or if the full name is typed in. I can see that this fixes the wait on long file lists. I should have delved a little further. It's more awkward if you're trying to select part of a path. If you type in *temp* then nothing appears. You need a slash before or after the name, i.e. *\temp* or *temp\*. Link to comment Share on other sites More sharing options...
