souliloquy Posted September 6, 2011 Share Posted September 6, 2011 I just got speccy and noticed that when looking the the temps it gives them in C by default. Well it says my cpu is at 66 degrees celsius. Which is about 150 degrees fahrenheit. It really feels like the numbers are wrong here. My laptop shuts down if my cpu ever gets to 90 degrees fahrenheit. Link to comment Share on other sites More sharing options...
kroozer Posted September 6, 2011 Share Posted September 6, 2011 Compare your Speccy reading with Core Temp or OpenHardwareMonitor. Link to comment Share on other sites More sharing options...
souliloquy Posted September 6, 2011 Author Share Posted September 6, 2011 I guess I was thinking too much those temps seem too high to me but after researching average temps they seem fine. Thanks a bunch. Link to comment Share on other sites More sharing options...
redhawk Posted September 6, 2011 Share Posted September 6, 2011 The temperatures are in range although a CPU above 60C may suggest insufficient air flow inside the casing. The processor temperature does vary depending on demand i.e. the harder it works the hotter it gets. Richard S. Link to comment Share on other sites More sharing options...
