Super Fast Posted August 8, 2011 Share Posted August 8, 2011 I noticed in the latest Defraggler 2.06, there are a few problems, such as: - Analysis Results ( looks more like a telephone than a ( mark. Left ( for Current State is the same way. Makes my screen look defective. LOL! - Analysis Results always maintains the exact same % fragmentation that Current State has. (Analysis is supposed to show the beginning fragmentation level, NOT = out to the Current State fragmentation level!) - No autosize available in options -> Every time I resize defraggler, it skews the size of the window boxes for all 3 sections in Defraggler. I have to scramble to drag the box just enough to see all my drives, then try to increase the size for the Analysis Results & Current State so that I can see both of them instead of looking at 1 of them (happens a lot when you resize Defraggler!) Please, fix the: - (telephone) style brackets - analysis results so they don't update to be "current" - Autosize to automatically size the 3 sections of Defraggler. At the least, give an option in autosize such that it will autofit & display all drives on your system, while maintaining a preset colored block window size, while maintaining a minimal size for viewing both analysis & current state results Please? Thank you guys! Your totally awesome! Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 9, 2011 Moderators Share Posted August 9, 2011 - Analysis Results ( looks more like a telephone than a ( mark. Left ( for Current State is the same way. Makes my screen look defective A screenshot would help. I don't know if you're referring to this or not, if so it's been reported by at least two people already. Link to comment Share on other sites More sharing options...
Super Fast Posted August 9, 2011 Author Share Posted August 9, 2011 A screenshot would help. I don't know if you're referring to this or not, if so it's been reported by at least two people already. Yes, that is it, I believe! I know it appears on XP Pro, but I am not certain on Vista or 7. I hear that others have no problem on Vista/7, hence the probably confusion. But it definitely shows on XP! Link to comment Share on other sites More sharing options...
Super Fast Posted August 12, 2011 Author Share Posted August 12, 2011 Although, I do hope the other 2 issues are fixed as well... I get tired of the boxes for the drives, as well as the size of the current and analysis results always changing, & skewing my view! Link to comment Share on other sites More sharing options...
