ZX 80 Posted October 14, 2010 Share Posted October 14, 2010 I just downloaded the new V of CC. I see it has a new entry in the windows tab (system) called ?FTP Account? but there is no explanation to what this is anywhere in the help section. I would be most grateful if anybody could tell me what this is or does please. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 14, 2010 Moderators Share Posted October 14, 2010 This has been asked often but hasn't yet been answered by the devs however what it does is delete (which windows will remake empty) the registry key HKCU\Software\Microsoft\Ftp\Accounts This key stores the information that is made when you use windows explorer to connect to a ftp (file transfer protocol) site (i.e. a remotly stored website directory where you upload your website to make it live). This key has the following information: Site, Username, Password. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
ZX 80 Posted October 14, 2010 Author Share Posted October 14, 2010 Thanks Link to comment Share on other sites More sharing options...
norel Posted October 15, 2010 Share Posted October 15, 2010 FTP stands for File Transfer Protocol. FTP Accounts are used for transferring files from one computer to another, like transferring Web pages from your computer to the server, for example. There's an article about it here: http://personalweb.about.com/od/ftpfileuploadprograms/a/01ftp.htm. It's one of those things that if you have it you'll know it, otherwise just forget about it. Link to comment Share on other sites More sharing options...
