frogbong1 Posted August 21, 2010 Share Posted August 21, 2010 I've downloaded Defraggler but the installer never pops up. Link to comment Share on other sites More sharing options...
redhawk Posted August 22, 2010 Share Posted August 22, 2010 You need to run the installer. Richard S. Link to comment Share on other sites More sharing options...
frogbong1 Posted August 22, 2010 Author Share Posted August 22, 2010 You need to run the installer. Richard S. I would love to but I cant find it. it would normally "pop up" after the download but it never does. Link to comment Share on other sites More sharing options...
frogbong1 Posted August 22, 2010 Author Share Posted August 22, 2010 I would love to but I cant find it. it would normally "pop up" after the download but it never does. okay so where do I find the installer? Link to comment Share on other sites More sharing options...
login123 Posted August 22, 2010 Share Posted August 22, 2010 Best way is maybe to download it again from filehippo, remember where you saved it, and run it from there. Filehippo is http://www.filehippo.com/download_defraggler click on "Download Latest Version 4.04MB" at top right. Select where to put it and remember that location. That will download a file called dfsetup121.exe Navigate to the file, dbl click it, and wallah, defraggler will install. If you want to find out if you actually downloaded it before, open windows explorer, right click on C: drive, click on search, and enter "dfsetup*.exe" without quotes. If you saved it to C: drive somewhere, that will find it, and you can decide what to do with it. The CCleaner SLIM version is always released a bit after any new version; when it is it will be HERE :-) Pssssst: ... It isn't really a cloud. Its a bunch of big, giant servers. Link to comment Share on other sites More sharing options...
