beatlebryce Posted May 24, 2010 Share Posted May 24, 2010 I'm on a pc that's using wifi to connect to my home network, and for some reason, when I run CCleaner, it makes my connection drop and it behaves strangely. It seems like my connection is always different. Does anyone know why this is and how I can prevent it? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 25, 2010 Moderators Share Posted May 25, 2010 do you have DNS cache checked off. if so that might be the reason ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
beatlebryce Posted May 25, 2010 Author Share Posted May 25, 2010 This option was already unchecked. Anything else? Link to comment Share on other sites More sharing options...
