Punisher2010 Posted April 26, 2010 Share Posted April 26, 2010 CCleaner does not clear the user's files and directories, in spite of their selection in the options Link to comment Share on other sites More sharing options...
Aethec Posted April 26, 2010 Share Posted April 26, 2010 What do you mean ? CCleaner has no option to clean something in the user's directory - except in %AppData% and %LocalAppData%. Piriform French translator Link to comment Share on other sites More sharing options...
Punisher2010 Posted April 26, 2010 Author Share Posted April 26, 2010 http://img232.imageshack.us/i/schowek01et.jpg/ CCleaner does not clear all of the attached folders,I mean avatars folders with Gadu Gadu Link to comment Share on other sites More sharing options...
Aethec Posted April 26, 2010 Share Posted April 26, 2010 Did you tick the "Custom Files and Folders" in the Advanced section ? Piriform French translator Link to comment Share on other sites More sharing options...
Punisher2010 Posted April 26, 2010 Author Share Posted April 26, 2010 Yes I have it checked, and only those folders I do not clean Avatars Link to comment Share on other sites More sharing options...
Alan_B Posted April 27, 2010 Share Posted April 27, 2010 Are you able to delete them, perhaps there are permissions issues, or they might contain something that is in use. Alan Link to comment Share on other sites More sharing options...
Punisher2010 Posted April 27, 2010 Author Share Posted April 27, 2010 Are you able to delete them, perhaps there are permissions issues, or they might contain something that is in use. Alan I am able to delete them manually even with the Gadu-Gadu. When turned off they can be manually removed, but CCleaner does not remove them Link to comment Share on other sites More sharing options...
